Author Topic: IS this Correct  (Read 1696 times)
Predator
  • Last login:November 13, 2004, 07:19:49 pm
IS this Correct
« on: November 13, 2004, 05:00:23 am »
Is the ATI R9200 video card the same as a
ArcadeVGA card ??
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
Re:IS this Correct
« Reply #1 on: November 13, 2004, 08:16:22 am »
The arcadeVGA is a Radeon 9200, but the Radeon 9200 is not an arcadeVGA :)
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
Re:IS this Correct
« Reply #2 on: November 13, 2004, 12:01:01 pm »
Don't quote me but I believe the ArcadeVGA card uses the ATI Raedon 7000 series chipset, unless the have update the card.
John
whammoed
  • Last login:Yesterday at 09:03:23 am
  • Crack don't smoke itself
    • NiceMite
Re:IS this Correct
« Reply #3 on: November 13, 2004, 01:04:28 pm »
John
they have...9200 now
jcrouse
    • CPViewer
Re:IS this Correct
« Reply #4 on: November 13, 2004, 01:08:05 pm »
OK, thanks for that information. Personally I don't use the product but may try one on my next cabinet.
Thanks again,
John
Predator
Re:IS this Correct
« Reply #5 on: November 13, 2004, 07:22:05 pm »
I am asking because i work with Computers and can get hardware at cost price.
So will the Radeon 9200 work on a Arcade Monitor
DaemonCollector
Re:IS this Correct
« Reply #6 on: November 13, 2004, 07:43:41 pm »
Nope, the ArcadeVGA has a custom written bios that allows it to output very low resoultions, a standard 9200 can't output below 640x480. Also the AVGA outputs a 15kHz refresh rate required by Standard res arcade monitors
Raven..
  • Last login:June 29, 2021, 12:51:50 am
Re:IS this Correct
« Reply #7 on: November 15, 2004, 11:40:17 pm »
YOu can use a standard ATI card and Advcab for DOS on an arcade monitor.  Then use Advmame as a front end.  Works just fine.  If you want to run Windows, get Power strip and program in the correct resolution to output on your arcade monitor.  It just takes a bit more work.
I have a Radeon 7000 in one of my MAME cabs right now.  I have built 4 of them with standard res monitors and have never touched an AVGA card.
paigeoliver
  • Awesome face!
Re:IS this Correct
« Reply #8 on: November 16, 2004, 03:10:44 am »
It isn't JUST the bios, I have one of the newest ones, it has hardware differences too, unless ATI now ships cards with partially removed svideo ports on the back of them.
