Author Topic: Could it be the definitive solution PS2/Jamma  (Read 996 times)
Darth Nuno
  • Last login:May 08, 2024, 04:26:02 pm
  • Namco is God !
    • Arcade Lifestyle / Dragon's Lair Fans
« on: November 11, 2004, 03:46:17 pm »
Look at this :
on this website : http://www.xinga.com/shop/show.php?product=P21150
The description on the website isn't clear... but it seems to be a way to connect Playstation II to a Jamma board ???  ???
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Could it be the definitive solution PS2/Jamma
« Reply #1 on: November 11, 2004, 08:20:18 pm »
I believe this is the same board as the MGCD.  It supports PS/PS2, Dreamcast, xbox and I believe Saturn.  Just uses different connectors.  Its been out for a couple years now.
http://www.frolicker.com.tw/mgcd/mgcd.htm
FYI, there is limited support for certain games under certain modes (see the sites game list).  Consensus is its still cheaper to hack it yourself if you are just looking to play a console inside your cab.  If you want to charge your friends time on the cab, then go ahead and try this out.
« Last Edit: November 11, 2004, 08:24:27 pm by Dave_K. »
