Author Topic: Simple FE that looks like Gamelauncher (but isn't Gamelauncher)?  (Read 3605 times)
  • Last login:Yesterday at 12:10:15 pm
« on: November 11, 2004, 03:30:43 pm »
I give up.  I just can't get gamelauncher working on my computer.  Everything is set up correctly as far as I can tell but when I launch gamelauncher and the game list screen comes up I am not able to select any of the games on my list.  When I try to scroll down it always returns to the top of the list and I don't feel like playing 1942 for the rest of my life (no matter how awesome it is ;)).  Otherwise it seems to work perfectly.
Anyway, is there another FE someone can recommend that has the simple look of Gamelauncher (gamelist on top of screenshot)?  When my cab is complete I don't want there to be too much confusion when people are trying to use it....  Thanks!  ;D
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re:Simple FE that looks like Gamelauncher (but isn't Gamelauncher)?
« Reply #1 on: November 11, 2004, 03:37:26 pm »
  I'm pretty sure MAMEWAH + the GameLauncher skin from Screenshot Archive will work if you're bent on the GameLauncher look and feel.
  -Steve
Minwah
    • MAMEWAH
« Reply #2 on: November 11, 2004, 04:34:22 pm »
I think Howard also has an 'updated GameLauncher' skin for DK.
IMO I don't think the GameLauncher-style MW skin would work too well (due to limitations of MW) - making an artwork image the same size as the screen, particularly with transparent text over it usually encourages large amounts of flicker (& possibly slowdown).  I haven't tried that particular one tho  ::)
« Last Edit: November 11, 2004, 04:34:38 pm by Minwah »
SteveJ34
  • Last login:January 06, 2024, 12:29:40 am
« Reply #3 on: November 11, 2004, 11:17:39 pm »
I had some trouble getting game launcher setup but in the end it was all a result of a short between my chair and the keyboard.
If you would like for someone to review your gluanch and mame config files I will raise my hand.
I don't guarantee success but willing to help if I can.
Send PM.
Apollo
    • Eight Bells
« Reply #4 on: November 12, 2004, 03:14:25 am »
Why don't you just use Mamewah, it's simple to set up, looks clean and has a screen shot right there in front of you. Don't know why you need a whole screen snap. Mamewah is virtually foolproof, hey if I can set it up anyone can. The new version has a much simpler menu set up as well.
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« Reply #5 on: November 12, 2004, 01:26:47 pm »
Show me something foolproof and I'll show you a bigger fool.   :o
It took me a few hours just to get one game to work on Mamewah.
Couldn't get anything to come up on Game Launcher.  These are great FE's and
I want to thank all of them for taking the time to develop them.
It may be simple for those of you whos been tinkering with FE for awhile but
for newbies like myself, I am the fool that will break any foolproofing you do  :-[
All us newbies out there, just keep trying and one day it'll be a piece of cake for us too. ;)
My advice for setting any FE cfg's up is to do a little at a time and check your work.
Dont try to do too much like set up a dozen skins and 1000's of games up.  This way,
its easy to back track if anything went wrong.  And anyways keep backup of last known
working step.
Teamwork - A group of people running around doing what I say.
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #6 on: November 12, 2004, 02:44:29 pm »
I would also be willing to look over your GameLauncher .cfg, .rom, and .map files.
I have several different emulators working with GameLauncher.
« Reply #7 on: November 12, 2004, 03:15:02 pm »
Thanks for the offers to help!  I love this board...
OK, here's my glaunch.cfg file - I hope you can tell me what's wrong...
# Overall configuration options
[Main]
# A list of emulators to launch.  There should be a config file in the
# config/ directory for each emulator listed.  The order listed here
# is the order they are displayed.
#  i.e. emulators = mame nesticle callus stella genecyst zsnes
emulators = mame
# If you have problems getting an emulator to run, try setting debug
# to "yes".  Also, check the logs/ directory.
debug = no
# The orientation of the menu.
#  0: Horizontal
#  1: Vertical
menu_orientation = 0
# Screen resolution.  Separate the width and height by a space.  For
# example, to specify 800x600 use this: resolution = 800 600.  If left
# commented out, the default resolution for a horizontal menu
# orientation is 800x600 and the default for a vertical menu
# orientation is 640x480.
# The True Type font to use.
font_file = slicker.ttf
# The size, in points, of the font.
font_size = 18
# Whether or not to use anti-aliasing on the font.  This looks nice, so
# unless you've got a *really* slow machine, I would use it.
antialias_font = yes
# Milliseconds of delay before the screen shot is displayed after moving
# the cursor onto a selection.
screen_shot_delay = 400
# How bright is the displayed screen shot (0 - 100)
# 0 - Black, 100 - full brightness
screen_shot_brightness = 40
# Whether or not to prefer integer scaling factors of screen shots
# over non-integer scaling factors.  If enabled, then integer scaling
# factors will be tried before non-integer scaling factors.  If
# disabled, then non-integer scaling factors will always be used.
# Note that non-integer scaling factors will result in some distortion
# of the screen shot.  It is for this reason that integer scaling is
# enabled by default.
prefer_integer_scaling = yes
# Background music type:
#  0: None
#  1: MP3 playlist
#  2: Compact Disc in CD-ROM (DOS Only)
background_music = 0
# Path to the MP3 playlist file.  Only relevant when background_music = 1.
mp3_playlist_file = ./playlist.txt
# CD Volume (0 - 1000). 0 - Min, 1000 - Max. Only relevant when
# background_music = 1.
mp3_volume = 1000
# background_music = 2.  For some reason the CD is really loud on my
# machine.
cd_volume = 450
# Sound effect volume (0 - 1000). 0 - Min, 1000 - Max.
sound_effect_volume = 1000
# Use software audio mixer (Windows only).  Set to "no" by default,
# but if you get distortion try turning it on as some DirectSound
# drivers have buggy mixers.
use_software_mixer = no
# This path is appended to all relative paths in the per-emulator
# config files.  It is a good idea to at least put the drive letter
# here in case DOS/Windows decides to change it.
path_prefix = c:\
# The number of minutes until the screen saver activates.  Setting to
# 0 disables the screen saver.  The default is 5 minutes.
screen_saver_time = 5
# The text to display when the screen saver is active.
screen_saver_text = Game Launcher
# The delay in milliseconds between the first key press and autorepeat.
initial_key_delay = 250
# The delay in milliseconds between key repeats during autorepeat.
# Make sure this is less than screen_shot_delay for optimal
# performance.
key_repeat_delay = 125
# The delay in milliseconds between the first joystick action and
# autorepeat.
initial_joystick_delay = 300
# The delay in milliseconds before advancing to the next item when
# using joystick autorepeat.  Make sure this is less than
# screen_shot_delay for optimal performance.
joystick_repeat_delay = 125
# Whether or not to show an icon next to games that have a screen shot
# available: "yes" or "no".  Default "yes".
show_screen_shot_icon = no
# Whether or not to use text animations such as smooth scrolling.
use_animations = yes
# The number of screenfuls to page up (or page down) before turbo
# scrolling kicks in.  Set to -1 to disable turbo scrolling.  When
# turbo scrolling kicks in, the smooth animated scrolling is turned
# off, thus allowing items to scroll by much faster.  Default 3.
turbo_scroll_threshold = -1
# The minimum number of items in a menu for it to be considered large.
# Small menus do not trigger turbo scrolling, regardless of
# turbo_scroll_threshold.  Default 100.
large_menu_threshold = 100
# The colors of the menu.  Each color is a red, green, blue triad
# (without commas).  The "fg" colors are the main text colors and the
# outline is the border of the text.
# Default: White = 192 192 192
unselected_fg_color = 192 192 192
# Default: Black = 0 0 0
unselected_outline_color = 0  0  0
selected_fg_color = 0 0 0
# Default: Yellow = 192 192 64
selected_outline_color = 192 192 64
# The color of title and sub-title.  Default: White = 192 192 192
title_color = 192 192 192
# Key mappings.  Use integer scancodes in scancode.txt, i.e. A = 1
# Default: Up Arrow = 84
up_key = 84
# Default: Down Arrow = 85
down_key = 85
# Default: Left Arrow = 82
page_up_key = 82
# Default: Right Arrow = 83
page_down_key = 83
# Default: 1 = 28
play_game_key = 28
# Default: Left Control = 98
next_emulator_key = 98
# Default: ALT = 100
previous_emulator_key = 100
# Default: ESC = 59
quit_key = 59
# Default: Space = 75
screen_shot_key = 75
# Skips to next song when pressed.
# Default: G = 7
skip_song_key = 7
# Starts current song over from the beginning.
# Default: D = 4
start_song_over_key = 4
# Joystick button used to play game. Valid values are 0 through the
# the number of buttons your joystick has.
# Default: 0
joystick_select_button = 0
# Which mouse axis to use as an input.  This can be used to allow a
# mouse, trackball, or trackwheel to control the menu.
#  0: No mouse control
#  1: X-Axis
#  2: Reversed X-Axis
#  3: Y-Axis
#  4: Reveresed Y-Axis
mouse_input_axis = 3
# How many pixels of mouse movement are needed to register as one
# line of movement.
mouse_input_threshold = 250
# Choose the animation method to use.  Page flipping results in the
# highest frames per second and smoothest animation, but may not work
# well with some cards.
#  0: Double Buffering
#  1: Page Flipping
animation_method = 1
# This option is only relevant when the animation method is double
# buffering.  Using vsync results in smoother animation, but may be
# slower.
use_vsync = yes
# This option is mainly for debugging purposes.  It allows you to
# disable use of video RAM for animation.
use_vram = yes
# If set to "no", Game Launcher will run in a window rather than
# fullscreen.  This only works under Linux and Windows, but don't use
# it unless you know what you are doing.
use_fullscreen = yes
RacerX
« Reply #8 on: November 12, 2004, 05:08:04 pm »
I don't see anything wrong with glaunch.cfg as you posted it.  I'll be out all night tonight, but when I'm home tomorrow, I'll compare it to mine unless someone else on the boards finds something first.  I would think the issue would be in the key assignments, but those are all the defaults...   ???
« Reply #9 on: November 12, 2004, 06:13:08 pm »
For the record, gamelauncher and xp don't always work well together, so that may be the problem.  However I agree that you should give it another shot.
In regards the the mamewah "marks".... geese man even minwah himself said a gamelauncher skin isn't gonna work well and you recomend it anyway.  We know you love it guys but you can't reccomend it for situations in which it can't do what the requestor is asking.  That's about as dumb as reccomending 3darcade to a person that wants a fe that'll run with super low system specs.
As he said... I've got it covered.
http://www.oscarcontrols.com/lazarus/skins2.html
Check out the bottom skin.... Almost exactly like gamelauncher with the added benefits of alpha blending and video textures (you can use video previews and they won't show in front of the gamelist).
Afaik the windows gdi (what mamewah uses) can't handle such large textures without severe flickering and it definately can't handle videos treated as textures.
MameJunkie
  • Eeeeeeeevil
« Reply #10 on: November 12, 2004, 06:51:45 pm »
Very nice Howard...
Something new for me to look at and play with  ;D
SteveJ34
« Reply #11 on: November 13, 2004, 07:04:59 am »
8<---snip----->8
I dropped your glaunch config into my setup and it works without issue. So far so good. Therefore, there perhaps is something amiss with your mame setup.
On the box I am testing with, my primary directory setup is:
C:\mame
C:\mame\roms
C:\mame\glaunch : for glauncher
Report how you have things stored, ie: what your directory structure is (similar to the above) and post your mame.cfg config file from glaunch\config directory.
Zapper
  • Last login:October 07, 2006, 10:26:01 pm
  • The enemy's gate is down
« Reply #12 on: November 13, 2004, 01:44:47 pm »
The Lemon Launcher frontend is based on Game Launcher, but it's a bit confusing to configure. I haven't used Game Launcher in quite a while, could your menu problem be caused by a PC gamepad? I've seen a few programs that have acted strange when gamepads are plugged in.
"Three warps to the Bugger homeworld"
vader
  • Last login:December 27, 2025, 08:14:42 pm
  • I can't breathe in this thing !!
« Reply #13 on: November 13, 2004, 07:19:32 pm »
I must be totally FE illiterate as I can't get MameWah to work.....I will keep messing with it, but now I'm receiving some .dll error.  Can't read the number exactly because my screen res gets stupid when the happens.  I'm using the command line version of mame.....could that be the problem.  To show how in the dark I am, I've followed a couple guides to get this going and it is driving me nuts because there are alot of people out there using wah and loving it :(
Tim
Minwah
    • MAMEWAH
« Reply #14 on: November 14, 2004, 09:53:32 am »
Make sure you have installed the system files (separate download) and DirectX 8 or above.
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #15 on: November 15, 2004, 10:28:12 am »
FWIW, I have the screenshots set to the same size as the screen and it seems to work great.
« Reply #16 on: November 15, 2004, 01:41:17 pm »
8<---snip----->8
C:\mame
C:\mame\roms
Thanks a lot for the help!  I will report back tonight with what you asked for...  I really want to get this working...
« Last Edit: November 15, 2004, 01:41:42 pm by javeryh »
« Reply #17 on: November 15, 2004, 01:43:47 pm »
If this is what the problem is I'm going to jump out my window.  Thank you!  I will try unplugging my game controller tonight and reboot and see what happens...
Minwah
    • MAMEWAH
« Reply #18 on: November 15, 2004, 02:50:25 pm »
Cool :)  Maybe it works better than I thought then!  Care to post a screenshot?
« Reply #19 on: November 22, 2004, 04:15:22 pm »
Zapper
« Reply #20 on: November 22, 2004, 05:24:06 pm »
Holy crap I think this is what the problem was.  I deleted and reinstalled mame and gamelauncher (for around the 10th time) but this time I unplugged my usb game controller and after configuration everything appears to be working as it should.  Unbelievable.  Thanks!!!!
Good deal  ...and please don't do a Peter Pan out the window :)
