Author Topic: MAME version  (Read 1336 times)
aeroflott
  • Last login:October 13, 2012, 04:50:01 pm
MAME version
« on: November 10, 2004, 11:35:06 am »
About to upgrade to MAME .88 under Mamewah, and I can't remember which version of MAME I'm running.
Which version do I download from http://www.mame.net/downmain.html
Command line or DOS? Does it make a difference?
Also, should I overwrite the relevant files I have (ver .78) or do a full clean install?
I'm running XP Pro.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re:MAME version
« Reply #1 on: November 10, 2004, 12:01:39 pm »
You want the "command-line" version.  It definitely makes a difference :)
Realistically you should start fresh, but you'll lose all your highscores and certainly the catver.ini and mameinfo.dat informations have changed.
  It's possible that you can just overwrite the old MAME installation with the new one, but be catious as wackiness can ensue.
-Steve
Edit: sp.
« Last Edit: November 10, 2004, 12:15:18 pm by screaming »
aeroflott
Re:MAME version
« Reply #2 on: November 10, 2004, 12:04:39 pm »
Cheers Steve. Going for an upgrade of MAMEWAH too - wish me luck.
Final quickie - how can I determne what version of Direct X I'm running?
Ta
screaming
  • Registered lUser
Re:MAME version
« Reply #3 on: November 10, 2004, 12:14:13 pm »
Ta
  Start->Run and type dxdiag
  If you're running XP, you probably have version 8 or 9.
-Steve
aeroflott
Re:MAME version
« Reply #4 on: November 10, 2004, 12:20:25 pm »
Nice one. Doubtless more issues will arise as I play around tonight. Watch this space.
Cheers
Tony
