Author Topic: Command Line IPAC Settings  (Read 2403 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« on: November 07, 2004, 12:36:15 pm »
Is there a way, perhaps using the command line, to load the IPAC config file?
I have different controls I need for different emulators. I know I can change the controls in the emulators but I am assigning other keys. Just wondering if there is a way to load the config file?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re:Command Line IPAC Settings
« Reply #1 on: November 07, 2004, 04:31:10 pm »
Yes, you can simply run the WinIPAC program from a command line or batch file ie
Winipac.exe myconfig.ipc
It will download the specified file to the board and then the dialog box will close.
Andy
sac01
  • Last login:February 27, 2016, 08:15:22 am
« Reply #2 on: November 07, 2004, 05:38:38 pm »
Hey Andy, is there a way to get the keyboard leds to turn off after programing the i-pac.. the programing turn the leds on, but never turns them off after
thx
sac
Minwah
    • MAMEWAH
« Reply #3 on: November 08, 2004, 05:26:48 am »
MAMEWAH can use WinIPAC to program the IPAC previous to / after launching emulators / PC apps.
Next release will be able to turn on/off the keyboard LED's ;)
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #4 on: November 08, 2004, 03:47:00 pm »
Hey MinWah, any chance that the pop-up dialog could be integrated into Mamewah? It is kind of ugly, and takes away from the arcade experience. Other than that, the IPC support is AWESOME.
Thanks, Fred.
sac01
« Reply #5 on: November 08, 2004, 05:51:26 pm »
you mean hiding the "programing I-pac" dialog?? I was just thinking the same thing
sac
Hiub1
« Reply #6 on: November 08, 2004, 10:04:41 pm »
I would not want to hide it completely, since it is useful to see what it's doing, but more like integrating it more to the frontend. Another thing that is hard to get used to is not touching anything while the ipac programs. Manthat drives me nuts!
Minwah
    • MAMEWAH
« Reply #7 on: November 09, 2004, 05:39:11 am »
Unfortunately I don't think I can hide that dialog box - WinIPAC takes over when it is launched.  There's nothing I can do about it, unless the WinIPAC author were to add a commandline switch (eg -nodialog).  I'm assuming it doesn't already have that function but I haven't used the latest version...
