Author Topic: Scan Converter or Video Card  (Read 2680 times)
kgriffin
  • Last login:August 31, 2002, 02:11:24 pm
  • I look nothing like Brad Pitt!
« on: September 19, 2002, 11:37:33 am »
I have found a cheap used scan converter (much cheaper than a video card with TV out). What would you guys suggest to output to TV. What are the pros and cons of using a scan converter instead of a video card. Would the onboard memory on a video card boost my frames per second or will it just get me output to a tv.
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
Re:Scan Converter or Video Card
« Reply #1 on: September 19, 2002, 06:40:39 pm »
Well,
no matter how good your scan converter is,tv still suck.
It doesn't make a lot of difference when it comes to tv.
If you got a deal on $1000+ scan converter that has rgb input and outputs vga then get the converter and use windows on arcade monitor.
i heard most do 640x480.
Some converters even do 800x600.
An ati video card is best solution for tv so dont bother using scan converter if you are using tv.
« Last Edit: September 19, 2002, 06:41:56 pm by SNAAAKE »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: September 19, 2002, 09:59:05 pm »
Does the scan convertor output anything decent?  like svideo or component?  or just RCA?
If RCA, get a ATI with svideo out or the component dongle if your TV can handle component.
However, if oyu plan on just playing older games, the scan convertor is just fine.
kgriffin
« Reply #3 on: September 20, 2002, 11:01:00 am »
The scan converter puts out s-video as well as composite. It seems though that the auction has some last minute bidders that took it up high enough that I will get an ATI card instead.
SNAAKE, my cabinet is a mulitpurpose unit. It is not only my arcade cabinet, but my Television and my recording studio. I have a home project digital recording studio that uses Logic Audio. I need a large television to get all of my mixing components on one screen as well as a way to watch College Football and play arcade games. It seems the TV is my best choice to accomplish all of this.
SNAAAKE
  • -Banned-
« Reply #4 on: September 20, 2002, 01:50:32 pm »
Then go with ati card..
Ati rage fury is only like $35 these days.That card is great for tv out.It outputs s-video.
