Author Topic: Choppy TV-Out  (Read 1573 times)
Thread Killer
  • Last login:March 26, 2008, 12:24:13 am
Choppy TV-Out
« on: November 06, 2004, 01:19:13 am »
I assume that NTSC TVs have a refresh rate of 60 Hz, but even in games designed to run at that frequency, MAME can be choppy for one frame every 10 seconds or so through my TV.
I have MAME set to a refresh rate of 60, triple buffering is enabled, autoframeskip is off, and frameskip is set to 0. Still, every once in a while, the picture noticeably 'stalls' for a frame. This is evident in Fatal Fury's attract mode (the screen where a character stands on a mountain as the game's title scrolls by) and on Super Puzzle Fighter II Turbo's difficulty select screen (look at the scrolling "Puzzle Fighter II" background), to give a couple of examples.
It is not a problem with my system's performance, as I can run the two aforementioned games at 300+% unthrottled. Also, if I run both the TV and a computer monitor simultaneously and do a side-by-side comparison, the latter's picture will not stall when the former's does.
I'm guessing that it is either a problem with my TV or with my video card (nVidia GeForce series.) Has anyone else experienced similar problems with MAME through TV-Out?
« Last Edit: November 06, 2004, 01:36:02 am by Johnny Cage »
Matt, GoC
  • Last login:August 18, 2005, 02:00:07 am
  • Must... stop... itching!!!
    • GameOn!
Re:Choppy TV-Out
« Reply #1 on: November 06, 2004, 02:25:44 am »
I think the video card is giving priority to the monitor over the TV, since the card has to process data for each display device.  I don't have an nVidia but my ATI card's manual states that having a TV and monitor gives a performance hit.  And yes, I see that skip too.  I'll bet that if you hooked up a cable to your VGA port, ran it through a VGA-TV converter, and then it went to a TV, it wouldn't be noticeable.  I've heard that nVidia's TV out can be hit or miss, so that could be a problem.
anthonylitz
  • Last login:October 18, 2009, 03:02:00 pm
  • Can you milk a llama?
Re:Choppy TV-Out
« Reply #2 on: November 07, 2004, 05:50:36 pm »
I am woundering why I have never heard of such a converter?!
Is it not what I think it is?  Sounds better than s-video, is it not?
Thanks, sorry to be off topic.
Anthony
Matt, GoC
    • GameOn!
Re:Choppy TV-Out
« Reply #3 on: November 07, 2004, 06:53:47 pm »
