Author Topic: Looking for a black finish for bolts/hardware?  (Read 1891 times)
OSCAR
    • Oscar Controls
« on: September 18, 2002, 08:27:37 pm »
I
1UP
  • Token Junkie
    • 1UPArcade
Re:Looking for a black finish for bolts/hardware?
« Reply #1 on: September 18, 2002, 08:36:22 pm »
Someone also posted before about using Rustoleum High-Heat black paint on some bolts, which can be heated up to 1000 degrees or more.  They said that after letting the paint air-dry, bake them in the oven at 400-500 degrees for 30 minutes (?) and they cure to an almost unscratchable finish.  I was going to try this, but ended up that none of my bolts would be showing anyway...  :-\  I might still try re-painting my coin door with this stuff if I can easily remove the original paint and plastic parts.
Anyone tried this?
My other job...
OSCAR
    • Oscar Controls
« Reply #2 on: September 18, 2002, 08:44:08 pm »
I've tried the high heat stuff for made for grills and stuff.  It works pretty good, too.  Of the two, I prefer the finish of the epoxy I linked for smaller items like bolt heads because it makes them look so crisp and clean.
But... I wouldn't use it on a coin door.  The reason I decided not to use it for my mounting plates is because they came out looking like mirrors.  I could literally see my reflection in them, and they looked out of place on a control panel because they were so bright.  I would rather go with the dull, high heat paint for a coin door because that would look a lot more like the original finish.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: September 18, 2002, 08:53:55 pm »
One of the distributors around here (CT) was offering to powdercoat coin doors for like 20 dollars (plus shipping)
he could do exotic colors and wrinkle finish...
Although I used some appliance finish paint for my coin door...  but if you were a perfectionist with extra money you could go the powerdoating  route...
*Shrug*
rampy
PS thanks for the tip though on that other paint oscar.
