Author Topic: Sending a signal after n seconds  (Read 969 times)
brained
  • Last login:October 07, 2025, 10:17:53 am
  • Raised by Atari
    • Nux
« on: November 01, 2004, 06:52:42 pm »
Hi all, I'm just wondering something. Can you wire a button with some sort of device that enables the button to send a signal after a few seconds. For an example, just like the pc power, if you press power for about 4 seconds the pc shuts down.
I want to do this because I don't want to accidentally press esc while playing a game.
I think capacitors are the thing  for this situation.
rdagger
Re:Sending a signal after n seconds
« Reply #1 on: November 01, 2004, 07:44:40 pm »
You could use a 555 timer to build a delay circuit.  You could add a variable resistor to adjust the delay.  Here is a diagram to get started.
Instead you could try a pushbutton with a cover or use a shift key.  Also if you are into AVR chips, you could program an AT90S2313 to act as a delay circuit.
