Author Topic: Snaps in Mamewah - need help :)  (Read 1220 times)
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
« on: October 29, 2004, 02:52:46 pm »
Okay - I had Mamewah working nice and smoothly with all my EMUs. And actually it still does work nice and smoothly, only my snap folders aren't showing.
All I did was upgrade to a new hard drive so I could add a few more EMUs. I copied everything across, and now although they all work as before, I can't get the artwork files to show. I checked and double checked that the path is correct (e.g. for Mame it's C:\Mame\snaps). I also tried that path in all 10 options in the 'EMU1' cfg file and no show.
I'm using Mr Salty's 640 x 480 layout, which does shoe perfectly as before. I'm a bit stumped as I'm using the same cfg pasted across from when it worked perfectly.
Any ideas?
Thx! TJ
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
Cave
  • Last login:June 07, 2009, 10:27:58 am
Re:Snaps in Mamewah - need help :)
« Reply #1 on: October 29, 2004, 02:58:53 pm »
Mamewah needs to be reinstalled on a new setup, a dll file gets installed, paintx.dll i think and this isn't in the mamewah folder.
Cave
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #2 on: October 29, 2004, 03:15:46 pm »
what he said. re-install or search the forums for the exact instructions on how to re-register paintX.dll
Halo
  • I'm a lamer!
« Reply #3 on: October 29, 2004, 03:52:12 pm »
Great - off to search now, many thanks :)
« Reply #4 on: October 30, 2004, 10:55:14 am »
Just install the system files from my site - that should do it.
