Author Topic: Router bit for T-Molding??  (Read 4716 times)
brandon
  • Last login:June 08, 2025, 02:40:01 pm
  • I <3 arcade games.
« on: September 16, 2002, 03:41:27 pm »
this is probably a dumb question and I might get flamed but what kind of bit do you use for T-molding and where do I get one?  I've been to Lowe's and they dont have anything like it...
hyiu
    • www
Re:Router bit for T-Molding??
« Reply #1 on: September 16, 2002, 04:01:35 pm »
I asked the exact same question before....
here is a link to that thread....
;D  ;D  ;)
but I used a dremel tool instead of a router....
hope it helps....
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=201;start=0
ps: and if your gap is not perfect.... hot melt glue gun can help too.... heee hee....
1UP
  • Token Junkie
    • 1UPArcade
« Reply #2 on: September 16, 2002, 04:28:19 pm »
The right bit is called a slot cutter.  Home depot has them, you want the 1/16 inch size.  You also need to get the arbor, which is the shaft the bit mounts on.  The manufacturer is Oldham.  The job will take just a few minutes with this bit instead of a dremel, and will be perfectly straight.  Wear some gloves, though, your skin will get sand-blasted with wood, no joke!  It looks like this:
My other job...
brandon
« Reply #3 on: September 16, 2002, 04:33:04 pm »
cool! thanks!  Lowes didnt seem to have the blades or the arbor... I was thinking I could use a bolt for one if I could just find the blade, but I'll check Home Depot...
dones
  • Last login:May 12, 2022, 12:06:24 pm
« Reply #4 on: September 16, 2002, 05:10:34 pm »
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
« Reply #5 on: September 16, 2002, 06:36:01 pm »
I used a circular saw nice and straight, fast and the perfect sized slot.
OSCAR
    • Oscar Controls
« Reply #6 on: September 16, 2002, 06:39:33 pm »
I couldn't find one locally, so I bought mine online here:
http://www.coastaltool.com/cgi-bin/SoftCart.exe/a/ab/aman/slotting.htm?L+coastest+dkxv1470ff213621#cart
I purchased mine from Coastal Tools, too.  I think I hit nearly every Home Depot in the Metro Detroit area, and not one had slot cutters.  I never even talked to an employee who knew what they were.  :)
Coastal ships fast, too.  I've purchased from them 3 times now, and my order shows up 2 days after I place it.
