Author Topic: trackball + spinner, do I need anything special?  (Read 964 times)
big daddy
  • Last login:May 01, 2019, 12:16:13 pm
« on: October 28, 2004, 02:08:35 pm »
I have a ps2/usb trackball and I'm ordering the oscar spinner with USB connector kit.
Is that all I need to have a cp with a trackball that works for trackball games and a spinner that works with spinner games?  I guess I'm a little confused in that the pc recognizes both as a mouse, right?  So do I need any optipac or anything to get the 2 mice to be recognized at the same time (note: I don't plan on using them both at the same time, just want them both recognized so I could use 1 or the other for the appropriate games).
as long as I have the USB connector for both, I can plug both into usb ports and everything will work ok?
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
Re:trackball + spinner, do I need anything special?
« Reply #1 on: October 28, 2004, 02:30:01 pm »
That's how I set mine up and it works fine.
ErikRuud
« Reply #2 on: October 28, 2004, 03:52:05 pm »
Yes, it will work.
I have a ps/2 track ball and my spinner is hacked through a serial mouse.
The only small drawback is that they willl both be active at the same time, which means someone could screw up your game of Missile command by spinning the spinner.
American Laser Games Wrapper
O2em Rom Utility
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #3 on: October 28, 2004, 03:57:19 pm »
I wired both my spinner and trackball to the Opti-Pac.
It takes a few seconds to sense the control when you switch to another. Something like a five second delay. Definately ensures someone can't screw up your game of Missile Command :)
« Last Edit: October 28, 2004, 03:57:51 pm by Jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
whammoed
  • Last login:January 31, 2026, 10:01:01 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #4 on: October 28, 2004, 04:02:03 pm »
Yes, it will work.
yes, that is the good thing about advancemame though,  up to 4 seperate mice in linux and two in dos.  I have a toddler and he will play with the other controls why you are playing.  I believe analog mame may support multiple seperate mice also?
