Author Topic: Advice needed: Monitor juts out from cabinet  (Read 1435 times)
mkdevo
  • Last login:February 09, 2024, 09:31:59 pm
« on: October 28, 2004, 10:58:13 am »
so typically, monitors are 'recessed' in the cabinets, but mine jets out of the front. i don't mind it, i'm just wondering how i should handle it (ie, the area around it, in front of it, etc.).
you can see how it jets out in this pic:
the cabinet was originally a Sunset Riders cabinet, which i got gutted for $50. the monitor is a new WG D9200. i kinda wanted to put the monitor right in with what was there, rather than have to rig the cab to recess the monitor.
like i said, i don't mind where the monitor is, but i'm looking for advice for the area around and in front of the monitor, where a bezel/smoked plexi would typically go. there is virtually no room between the top of the monitor and the cabinet, but there is room around the sides and the bottom. just looking for some pointers for what to do with this room.
here's a picture of the front to try to give you an idea:
(and no, i'm nowhere near finished yet. the bottom front is going to be completely replaced, and will have a 4p coin door..)
thanks in advance.
« Last Edit: October 28, 2004, 02:40:29 pm by mkdevo »
Stingray
Re:Advice needed: Monitor jets out from cabinet
« Reply #1 on: October 28, 2004, 11:07:12 am »
I know you said you don't want to do this, but if it were mine I'd rebuild the area where the monitor mounts so that it can be recessed then put some tinted plexi in front of it.
-S
« Last Edit: October 28, 2004, 02:49:58 pm by Stingray »
danny_galaga
  • Last login:Yesterday at 06:37:38 am
    • dans cocktail lounge
« Reply #2 on: October 28, 2004, 11:39:36 am »
do you mean 'jut', rather than 'jet'? i was expecting to see a pic of your monitor flying out of the cab!! it does stick out a little but you wouldnt notice when your playing anyway. if its all finished id just tidy up the surround...
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
« Reply #3 on: October 28, 2004, 01:34:11 pm »
LOL danny... you beat me to my smart ass reply.  ;D
mkdevo
Re:Advice needed: Monitor juts out from cabinet
« Reply #4 on: October 28, 2004, 02:41:35 pm »
fixed, smartasses! now how bout some advice?  ;)
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: October 28, 2004, 02:52:20 pm »
Well, it looks like there are two ways to approach this:
1)  cut an open area in the back panel for the yoke to stick through, make a box to cover it, and move the monitor rails back so the monitor doesn't stick out.
2)  extend the side rails on the cab forward and attach your bezel/plexi to the extends.
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #6 on: October 28, 2004, 04:03:55 pm »
can you mount hte monitor to the back of the rails (behind the wood) instead of in front of?
not sure, but some time the obvious things get missed....
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: October 28, 2004, 06:42:48 pm »
Dude, the problem is your rails. Lower the rails and the whole monitor moves DOWN (vertically down--I'm not talking about moving it BACK where the neck will get inthe way of the back door). Down a few inches is all you need.
~Ray B.
NO MORE!!
