Author Topic: hacking a wingman warrior  (Read 1974 times)
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« on: September 16, 2002, 01:28:21 pm »
I haven't started yet, but I know a couple of you have done it before.
Any tips on dissassembly?  Is there  a trick to taking off the spinner knob.  It seems to have a ball bearing where I'd assume a little hex locking screw would be...
Thanks in advance!
Rampy
rampy
  • *shrug*
Re:hacking a wingman warrior
« Reply #1 on: September 18, 2002, 02:18:10 pm »
sorry to be annoying but *bump*
rampy
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #2 on: September 18, 2002, 03:51:44 pm »
Just take out all the screws to take the unit apart. I haven't taken the spinner out of mine (yet). I think the silver "bump" is probably a rod that goes through a hole in the shaft.
bob
turboc
  • Last login:October 30, 2004, 08:27:55 am
« Reply #3 on: September 18, 2002, 10:08:55 pm »
I've disassembled mine and installed into a control panel minus the joystick.  It works great.  Make sure you drill the correct size hole for the plastic guide that is under the spinner knob.   Also, I ended up thinning the panel slightly on the underside with a router to get the correct thickness.  The logic board and IR light sensor needs to be mounted as well.  To get the knob off, you need to pull the set pin.  I can't remember if it was held in place with locktite, but mine is just a friction fit now.
« Last Edit: September 18, 2002, 10:11:47 pm by turboc »
