Author Topic: Control Panel Number 2  (Read 3514 times)
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« on: October 28, 2004, 01:38:38 am »
I just received my Spinner from Oscar. Can't wait. Must build an interface. Attached picture is my first "throwaway" prototype "control panel" after a few hours of work...
Warning: Not pretty. Just Functional. To be accounted for into a final design...I wanted somewhere to hold the tb and spinner while I tested the wiring to the Opti-Pac.
Much to my surpsie, this panel was "butt ugly" but amazingly completely functional with a few buttons... I was able to play and relive long lost favourites such as...
   Missile Command
   Tempest
   Marble Madness
   Star Wars
   Arkanoid
   Revenge of DOH
   Centipede
   Millipede
   Championship Sprint
   Pole Position
   A Mini-Put game I used to play with a Trackball (84-85?)
Also, Bonus!!! Can now fully operate Windows with trackball and Left/Right Mouse Clicks. What a Treat!!! What was I doing with the "mouse hidden under the control panel trick!!!"???
I've been looking at www.localarcade.com and getting ideas for a new new control panel. This time, soemthing with some pizazz. I spotted a Major Havoc CPO recently uploaded by tbombaci. Very Nice!!! Could be the start of a new CPO?
Over the next little while, I will document the process I go through to get to my "perfect" control panel...Please stay tuned for further developments...
Edit: Made some minor typos edits..
Garry -
Edit: Changed title as I didn't want people to think that this was my real control pane.
« Last Edit: October 29, 2004, 05:28:52 pm by Jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
Jabba
  • D-Hutt
Re:My New Control Panel...
« Reply #1 on: October 28, 2004, 02:01:48 am »
Here is a pic of the guts...
My big puzzle was how to connect the Oscar Spinner wiring harness. After looking at http://www.oscarcontrols.com/images/spinner-connector.jpg
I finally figured it all out...
« Last Edit: October 28, 2004, 02:05:07 am by Jabba »
paigeoliver
  • Awesome face!
« Reply #2 on: October 28, 2004, 04:47:40 am »
I would completely and totally ditch those two buttons under the trackball. You should be able to tell from testing that you can't REALLY get buttons close enough to a 3" trackball to use the trackball and buttons with the same hand, at least not gameably. And if it isn't gameable then it doesn't need to be on the panel.
When I built a panel like this I simply put the spinner on far right, the trackball in the center and the three (mouse) buttons on the left. Worked like a charm.
Jabba
  • D-Hutt
« Reply #3 on: October 28, 2004, 02:49:54 pm »
Thanks for the feedback paigeoliver. Do you have a website or a picture of your control panel with the TB/Spinner? I am trying to gather as much info as I can before I start the real build.
Apollo
    • Eight Bells
Re:A hacked together "Test" Control Panel
« Reply #4 on: October 28, 2004, 06:29:53 pm »
My Trackball/spinner panel has 3 buttons in a triangle on the left and the right and in the middle is the spinner on the right and the trackball on the left works like a charm, you can just see it in this thread.
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=22004
« Reply #5 on: October 29, 2004, 11:35:08 am »
See my analog panel here:
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=20708;start=msg169495#msg169495
I guess I have my trackball or buttons in the wrong place for some...I wanted to keep buttons on the right of all controls.  Possibly I should have swapped the position of the buttons & spinner, so buttons are on the right for use with the joystick, and on the left of the trackball & spinner.
That said it plays fine for me, I will probably leave it as it is.
Jabba
  • D-Hutt
« Reply #6 on: October 29, 2004, 05:23:10 pm »
Appollo and Minwah,
Thanks for the links Very impressive work. Its giving me food for thought. My new control panel is going to accomodate TB, Spinner, Joys1/2 (maybe a pacman), and 4-6 pushbuttons (possibly leaf) for each player.
My cabinet was based off Lusid's design (wishing now I would have chosen defender...but oh well)
I previously bolted on a separate Control Panel that I've since disaaembled. I want something new, that integrates better with the Cabinet Here is a picture of the old setup (before I disaasembled it...
« Last Edit: October 29, 2004, 05:31:07 pm by Jabba »
Jabba
  • D-Hutt
« Reply #7 on: October 29, 2004, 05:27:37 pm »
I was never really happy with this one. It is not integrated with the cabinet. It is sharp with the Acrylic on the top and I generally want the lines to flow withough any breaks. Something more like defender.
I like the defender theme and loved how erikthecat (Cofin Mame) did his control panel.
http://www.splatthatcat.com/arcade/
Here are a couple of mock ups in Paint (low tech). Looking for comments and feedback.
Thanks in advance.
« Last Edit: October 29, 2004, 05:32:28 pm by Jabba »
Jabba
  • D-Hutt
« Reply #8 on: October 29, 2004, 05:28:30 pm »
Or maybe this.
Which do you guys prefer?
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
Re:Control Panel Number 2
« Reply #9 on: October 29, 2004, 11:36:59 pm »
I like number 2.  My first cab had a CP that was wider than the cab.  I quickly learned that a cab looks much more retro and authentic when  the CP is integral with the cab.
Jabba
  • D-Hutt
« Reply #10 on: November 04, 2004, 07:43:56 pm »
Thanks Santoro for your comment.
Spent a few hours in the shop, here is a rough cutout of the new CP. CP measures 26 x 18. A little bigger than I anticipated. Comments, suggestions? This fits ontop of the Lusid design.
Right now, the CP is laying on top of the sides. I am going to cut it down to 25" to fit between the sides.
Thanks for you input!
« Last Edit: November 04, 2004, 07:46:38 pm by Jabba »
