Author Topic: Need help with HAPP trackball wiring  (Read 1466 times)
rdagger
« on: October 26, 2004, 01:50:53 am »
I was testing a rotating cab design and I accidently pulled out the wires from the plug on my Happ 3" USB trackball. :(  The plug connects to the circuit board of the trackball  and has 4 wires: black, green, red and white.   The other end of the cable has a standard USB plug and PS/2 connector.  Does anyone know in what order the 4 wires should be connected or does anyone have any close up pictures of the 4 wire connector?  What happens if you plug it in wrong?
whammoed
  • Last login:Today at 01:35:01 pm
  • Crack don't smoke itself
    • NiceMite
Re:Need help with HAPP trackball wiring
« Reply #1 on: October 26, 2004, 03:49:34 pm »
used to have one but its gone now....do you see any lettering on the pcb... if you see a "G" that is likely where the black (ground) wire goes
rdagger
« Reply #2 on: October 26, 2004, 07:58:13 pm »
I found a wiring pinout here  and it worked.
