Author Topic: VirtuaNES - mouse appears?  (Read 1903 times)
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« on: October 25, 2004, 08:25:22 pm »
I've just setup VirtuaNES on my cab and have it working great except the mouse keeps appearing on the screen for about 4 seconds when a game loads.  Is there a setting to turn this off?  I've recently switched from FCEUltra on my cab cos I was getting screen tears and in VirtuaNES I got rid of this by tweaking a few settings.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re:VirtuaNES - mouse appears?
« Reply #1 on: October 25, 2004, 08:52:54 pm »
The mouse appears for me too, and I haven't found a way to get rid of it, except move it out of the way :-/
<Obligatory run-on sentence rant>
  Since a front-end is designed to launch emulators, and there are a lot more emulators than there are front ends, it seems to me that this feature, along with setting an exit key (a-la generic command-line wrapper) are functions that should be moved up to the FE level.
</Obligatory run-on sentence rant>
-Steve
« Reply #2 on: October 26, 2004, 05:06:39 am »
Not that easy unfortunately :(.  For example Windows keeps wanting to show the mouse cursor (particularly when launching other apps.) - I *think* HC may have tried to address this by using an invisible cursor (?).
Having a FE look for an 'exit key' would use CPU cycles (potentially slowing down the emulator).
