Author Topic: USB trackball and spinner with MAME32?  (Read 1023 times)
jdon
  • Newbie
  • Last login:October 25, 2004, 11:50:54 am
« on: October 25, 2004, 11:55:58 am »
Has anyone used or know of any issues using the HAPP USB trackball? Or OSCAR spinner with their usb interface. Oscar also makes a happ trackball harness that connects to their usb interface. Just wondering if USB would work as well as optipac? Thanks!
Dan
  • Last login:February 09, 2010, 11:52:34 pm
Re:USB trackball and spinner with MAME32?
« Reply #1 on: November 04, 2004, 08:09:58 pm »
I have both the Happ USB trackball and Oscar spinner controllers and they both work fine.  I just have a USB extension cable running into the back of my control box and plug it in when I switch panels.
Doc-
  • Last login:April 09, 2007, 01:04:51 am
  • Carpe Arcadium!
    • Doc's Modular MAME
« Reply #2 on: November 04, 2004, 09:26:01 pm »
All of the analog devices on my modular machine are USB and they all work fine.
Only issue you might eventually run into is if you have several USB devices plugged in and switch to analog mame or noname mame for multiplayer analog devices.  In this case, it becomes important which device is in which port since the first one will be player 1 by default, second player 2 and so on.
Since my panels are modular (for example) if I have a bunch of USB analog devices plugged in and then try to play a 2 player lightgun game (which are also USB treated as mice) it may pus my lightguns out to player 2, 3 or 4 which can be a pain.  In this case I just unplug the ones I'm not using and all is well again.
Doc-
