Author Topic: Happ Ms Pac VS Ultimarc J-Stik Balltop  (Read 3212 times)
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« on: October 22, 2004, 03:02:29 pm »
I'm building a Ms Pacman cocktail cab and want a 4-way balltop joy.
I was going to order the Happs Ms Pacman $20 but when I was ordering the encoder, I saw the J-Stik balltop (4/8 way $15).
Question is how does the J-Stik feel in the 4-way mode.  If its just as good, it seems like its a better deal.  Its cheaper and I can actually turn in into a 8-way.
Teamwork - A group of people running around doing what I say.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Re:Happ Ms Pac VS Ultimarc J-Stik Balltop
« Reply #1 on: October 22, 2004, 06:24:10 pm »
i'm also wondering if the j-stick would be good for a galaxian reproduction machine.
is there better alternative
or should i try and get a original 2 way?
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #2 on: October 22, 2004, 08:50:38 pm »
I've not played with the J-Stick, but you might also want to consider the T-Stick Plus balltop.  The action is much stiffer and the range of motion is much smaller, but you get a good positive 4 or 8-way feel, and it's switchable from above the CP.
MameJunkie
  • Eeeeeeeevil
« Reply #3 on: October 22, 2004, 09:34:49 pm »
Yes, I would like the T-Stik Plus w/Balltop...BUT its too expensive...way too expensive.
$24 for the T-Stik plus (not bad) but I have to get the balltop extra ($12-14).
So it ends up being $36-38.
I don't get why he doesn't just sell a T-Stik Plus balltop version without having to get the normal version with a balltop shaft extra.  Probably is a good reason but as of now, I dont have to budget to spend $72-76 for 2 joysticks.  Granted they are some of the nicer joysticks out there.
SteveJ34
  • Last login:January 06, 2024, 12:29:40 am
« Reply #4 on: October 22, 2004, 10:57:10 pm »
I'm in the same boat....
I'd like to go with a couple of T-Stick Plus with Ball Top for a couple of classic bartops I'm building but have hesitated based on the total price and then having (2) useless stick parts to boot.
Trenchbroom
  • Last login:November 21, 2020, 09:25:43 pm
  • Wampus? Get over here!
« Reply #5 on: October 23, 2004, 12:15:31 am »
I seem to be one of the few J-Stick advocates around.  I love 'em!  I also have a T-Stick balltop I've played around with for my cocktail cabinet (not completed) and the longer throw of the J-Stick just works for me.
The cocktail, when finally finished, will have a T-Stick on P1 side and a 20th anniversary on the other.  They won't match for squat but this way I can get all my vertical schmuppy goodness on the cocktail cab and still get sweet 2 player 4-way flipscreen oldschool gaming as well.
SteveJ34
« Reply #6 on: October 23, 2004, 09:52:56 am »
I've been considering the J-Stick as an alternative to the T-Stick and Happs Ms Pac.
One concern has been the length of the stick as I am likely to use a wood cp for the "classic" bartop projects I am working on.
Do you have yours mounted in metal or wood cp?
What's the distance between the top of mount and the bottom of the ball on the J-Stick?
rchadd
  • Made in Cornwall
« Reply #7 on: October 23, 2004, 11:10:44 am »
to mount the jstick (and tstick - unless you have the long handle version) on a wooden CP you will need to route out underneath.
bigle
  • Last login:August 10, 2006, 02:22:54 pm
  • i may or may not be a llama
« Reply #8 on: October 23, 2004, 02:40:06 pm »
i got the t-stik plus for the switchability but if you are building a classic machine i'd go with a dedicated 4-way.  i don't mind the short throw but my stick is way to high (i've got a metal cp) and stiff which makes playing fast ms pac man difficult.
who fishes with cheese?
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
« Reply #9 on: October 23, 2004, 03:37:39 pm »
I love the balltop J-Stick too for 4 way games. It works great for Nibbler and the Pac-Man games that I only play with the fast speed cheat enabled.
Will
  • Last login:April 08, 2012, 03:32:27 am
  • Finished Lurking.....
« Reply #10 on: October 23, 2004, 03:39:56 pm »
In the small testing ive done with the j-stick so far it is great.I cant give a full review yet because I havent done much testing but seems to be a great joystick for older 4-way classics..
