Author Topic: How you like dem panels!  (Read 3948 times)
1UP
  • Token Junkie
    • 1UPArcade
« on: September 15, 2002, 02:03:47 am »
My final design for a fully integrated rotating CP!  Here's a 3D rendering.  I've got about 2 hours worth of work and then it's done.  Much purtier than the prototype...
I'll be updating my site soon with pics of design, construction, and my first Mame party!  Stay tuned...  8)
« Last Edit: September 18, 2002, 05:44:39 am by 1UP »
My other job...
nullb0y
  • Slow In Fast Out
    • WAT Racing
Re:How you like dem panels!
« Reply #1 on: September 15, 2002, 02:18:37 am »
thqat is sweet!
Slow In Fast Out
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #2 on: September 15, 2002, 02:53:11 am »
But the question is: Does your monitor rotate too? *giggles*
Kidding... great design. How do you prevent the wires from tangling? Do you have to remember which direction you rotated it last and go backwards the next time?
If you build a frankenpanel, chances are I don't care for you as a person.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #3 on: September 15, 2002, 03:08:03 am »
Nope, I wouldn't leave things to chance like that.  The panels don't really rotate all the way around like that, it was just easier to loop the animation that way.  There is a metal plate on the inside wall of the cab that stops a screw on the panel end plate.  This way the panels can only rotate 240 degrees in either direction.  The Star Wars yoke is too big to fit thru underneath the monitor, so it's impossible to rotate 360 like that anyway.  The axles are short PVC tubes so the wires actually pass thru them, and then they go thru a routered 3/4" slot along the right side of the cabinet.
BTW, I'm temporarily using an old 21" TV for the monitor (the picture is about as big as it looks in the rendering), which already seems big enough to play vertical games on.  But I've left enough room inside to mount a WG 27" arcade monitor in a couple months.  That should be more than adequate...  ;D
« Last Edit: September 15, 2002, 03:12:35 am by 1UP »
My other job...
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #4 on: September 15, 2002, 03:20:02 am »
how do you use a rotated monitor ? i mean everyuthiung would be sideways or are there drivers that rotate everything?
Slow In Fast Out
1UP
  • Token Junkie
    • 1UPArcade
« Reply #5 on: September 15, 2002, 03:26:04 am »
You can set up Mame to rotate the picture 90 degrees, but I'm not interested in that.  I'm not such a purist that I'm going to bother spending time building the hardware to rotate a monitor, which has to be pretty small in order to rotate anyway.  If you can't stand the small picture when playing verticals on a horizontal screen, I say get over it or just get a bigger monitor.  ;)
My other job...
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #6 on: September 15, 2002, 06:17:44 am »
im ordering a video output cable and putting on a video impuit cardlol tv in tv out
Slow In Fast Out
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #7 on: September 15, 2002, 10:59:15 am »
Do you use mame32 or commandline mame?
at commandline use -ror or - rol  (rotation right or left).
There's also flipx and flipy.
in mame32 goto the game's properties, it's in there somewhere.
BobA
  • What Me Worry?
« Reply #8 on: September 15, 2002, 04:14:27 pm »
Looks really sharp.  I admire your ingenuity and craftsmanship.
BobA
Xiaou2
  • Last login:Yesterday at 11:09:11 pm
  • NOM NOM NOM
« Reply #9 on: September 15, 2002, 06:04:40 pm »
Hey 1up,  Great job on the design, and nice animation too  :D
 You may have beat me to the finish for the first 'completed'  rotating control, but Ill have mine done someday...  ;D
1UP
  • Token Junkie
    • 1UPArcade
« Reply #10 on: September 18, 2002, 05:56:30 am »
Yeah, uh, mine should be done by now!  2 hours worth of work but I'm just waiting for CP art now!  Damn Kinko's!  :P
My other job...
