Author Topic: Red Ball Top Joy, Wood Panel  (Read 949 times)
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« on: October 18, 2004, 10:06:19 am »
Making final equip plans for couple of bartop projects which will primarily be to play classics....
What are the options (vendors) for 4/8 way ball top joys that are to be mounted in wood panel?
I went with a 4 way ball top from Happs for my upright completed many moons ago. Mounted through 5/8 MDF panel its a little short but worked out okay.
Was searching here for other options/recommendations from others.
Is Ultimarc the only resource for switchable 4/8 way with red ball top and can the T-Stick Plus be purchased with a ball top handle or must it be seperate?
I look forward to any and all replies.
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
Re:Red Ball Top Joy, Wood Panel
« Reply #1 on: October 18, 2004, 10:25:50 am »
here's one from betson that some people are happy with:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=24743
the t-stick plus requires you to buy the ball-top handle seperately.  the j-stick is also a reasonable alternative depending on your tastes.
« Reply #2 on: October 18, 2004, 11:27:14 am »
I like the J-Stik the most, the T-Stik is good too.  Both of these are meant to be mounted to metal tho, but you can route your wood down to 1/4" or so and they should be fine.  The T-Stik plus has a slight advantage here, in that a 'long' balltop shaft is available.  In practice it is not an awful lot longer than the J-Stik tho...
