Author Topic: Mamewah with X-arcade  (Read 2179 times)
Cirrus
  • Last login:October 15, 2004, 11:09:02 pm
« on: October 18, 2004, 12:32:47 am »
I've spent a good part of the evening trying to get my x-arcade to work in Mamewah.  No luck.  Mostly, shouldn't the left controller (player 1) scroll through the games?  It does nothing.  I have to use the keyboard which is inside the case, and even then, the games are not responsive to the left joystick.
However, when I run Mame32, it works perfectly in games.  (However, still not on the menus before the games. )  I just have to use the keyboard for game selection.
Please help!
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
Re:Mamewah with X-arcade
« Reply #1 on: October 18, 2004, 01:29:39 am »
Did you change the "joystick 0" to "joystick 1" in the default.ini file that's in the ctrlr folder of mamewah? If that doesn't work then you'll have to use something like Joy2Key.
Cirrus
« Reply #2 on: October 18, 2004, 02:02:58 am »
Well, I just tried changing that 0 value to 1, but there was no change at all.  I wonder if I need to change the controls in the .ini file.
Also, why do you think it is that the controls work perfectly WITHIN a mame32 game, but not at all within a mame.exe (essentially) game?
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #3 on: October 18, 2004, 03:50:28 am »
You may need to reconfigurere mamewah controlsettings to use numpad instead of arrowkeys with your controller.
« Reply #4 on: October 18, 2004, 06:34:43 am »
That is correct, see: http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=9337&page=0&view=expanded&sb=5&o=&fpart=1&vc=1
Cirrus
« Reply #5 on: October 18, 2004, 09:13:37 am »
Thanks, that thread cleared things up.  Will probably do the trick.  ;)
MiahXGaming
  • Last login:May 26, 2016, 02:42:21 pm
  • Legend
    • X-Arcade
« Reply #6 on: October 22, 2004, 05:28:17 pm »
You can program the arrow keys on the X-Arcade, not sure what the issue is there...
« Reply #7 on: October 23, 2004, 12:35:28 pm »
The problem is that MAMEWAH is expecting cursors, and by default the X-Arcade uses the num. pad keys.  Remapping MAMEWAH's inputs is prob. easier than reprogramming the X-Arcade IMO...
