Author Topic: Primer Mistake  (Read 2176 times)
Lsturbo91
  • Last login:September 16, 2002, 11:51:05 pm
Primer Mistake
« on: September 14, 2002, 03:14:17 am »
I'm painting my cab and made a mistake of not priming it.  Its sorta of uneven.  Can I just put primer over the first coat or should I just put a 2nd coat of semi-gloss black?  I really don't wanna have to strip it again which means 2 days of sanding which is a whole different story  :-[.
My Cab Specs:
3/4" MDF Wood
Semi Gloss Black
« Last Edit: September 14, 2002, 03:24:11 am by Lsturbo91 »
Rahzel
  • Last login:May 14, 2025, 11:23:34 pm
  • MAME4LiFE
Re:Primer Mistake
« Reply #1 on: September 14, 2002, 06:52:54 am »
Primer is used to let the wood absorb some liquid before putting on the actual (expensive) paint. All new wood will suck up paint so that's why you put down a cheap layer or two of primer down first. If the first layer of paint you layed down was oil-based then you can't put anything water-based on top.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:Primer Mistake
« Reply #2 on: September 14, 2002, 09:04:50 am »
The first layer of paint is now your primer.
Normally a coat of primer and a coat of paint will suffice. Since you've gone the no primer route it may take 3 (or even more)coats of paint to make the finish nice. If the paint is really uneven you may even want to do a light sand between coats.
Skipping primer is NOT a shortcut.
If you build a frankenpanel, chances are I don't care for you as a person.
Lsturbo91
Re:Primer Mistake
« Reply #3 on: September 14, 2002, 03:27:43 pm »
Actually turned good now, I put a 2nd coat and its looking good.
