Author Topic: 3D Arcade Help please..  (Read 3192 times)
JesterDEV
  • Last login:November 25, 2010, 05:29:21 pm
  • OU812?
    • Jester's Temptation
« on: September 14, 2002, 12:34:28 am »
Well Im going through the bare bones area of the tutorial. I'm doing everything as it says to, and I get a script error every time!
The problem is that when I change the fearcadelist.cfg from:
all|2.0000|1.0000|
To:
favorites|2.0000|1.0000|
I get the script error.
Also when I just run it without all the editing exept for telling it where mame is at, I press 1 when I am in front of the game I want to play, and nothing happens.
What am I doing wrong???
Great big gobs of greasy grimey gopher guts.
MrArcade
  • Last login:May 29, 2025, 02:06:06 pm
  • I wish I had time to play these games !!!
Re:3D Arcade Help please..
« Reply #1 on: September 14, 2002, 01:50:21 am »
Here is my .\config\emulators\femame.cfg file...see if you have the same dir pattern....most things should start with the same path...
also, make sure the version of mame you are poitning to is set up correctly...
--pathnames
emupath|d:\arcade\mame2\|
gamepath||
workingdir|d:\arcade\mame2\|
shortnamepath||--some, mostly dos based, emus can't lauch games with long file names. for those set this path to the location you keep the games. for all others keep this empty. The fe will search this path for the filename and then it will use the shortname to launch it. Keep this also to false when you don't have the complete filename with extension in the gamelist!
sshot|d:\arcade\mame2\snap\|
marquees|d:\arcade\mame2\marquees\|
flyers|d:\arcade\mame2\flyers\|
cabinets|d:\arcade\mame2\cabinets\|
qtvr||
gameinfo||
glvideodir|g:\3dfe\dummys\videos\|
helppath||--you can put pics like cp layouts in here. the fe will search for them and when nothing is found show the general layout pic setup in the cfg file for the current skin
--executable options
mame|mame57h/mame57h|
emuoption||
altmame||
runstopsound|true|--when set to true the background sound will stop while you run a game. I like to keep the backgroundsound running while I play mame games...use the win32 not the dos version...it gives the feel of being in an arcade while playing :-)
Oh, the memories of living on pizza subs and Dr Pepper...
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #2 on: September 14, 2002, 03:01:08 am »
all|2.0000|1.0000|
To:
For mame just like mrarcade mentioned. if mame.exe dkong launches your game correctly from the commandline then it should work. if is does vnot launch from the commandline you have not set your rom path in mame.ini. You can then add it to your mame.ini or point gamepath|| from femame.cfg to your mame rompath.
About the srcipt error probably somewhere some typo...email me or if they are not to long post them your cfg\lists\favorites.atf and cfg\selsets\fearcade.cfg
peter
JesterDEV
  • OU812?
« Reply #3 on: September 14, 2002, 10:14:26 am »
Here are is my favorites.aft:   I just left a few in there from the original. Just testing to see if it works.
|1941 - Counter Attack (World)|1941|1990|Capcom|None|None|Shooter / Flying Vertical|.33b05|Yes|mame|arcade||Favorite|Raster|Vertical|224x384|3x4|60.000000|Unknown|No|Joy 8 Way|2|2|2|cps1.c|Good|Good|Good|||||||||
|1942 (set 1)|1942|1984|Capcom|None|None|Shooter / Flying Vertical|.19|Yes|mame|arcade||Favorite|Raster|Vertical|224x256|3x4|60.000000|Unknown|No|Joy 8 Way|2|2|2|1942.c|Good|Good|Good|||||||||
|Amidar|amidar|1981|Konami|None|None|Maze / Outline|.06|Yes|mame|arcade||Favorite|Raster|Vertical|224x256|3x4|60.606060|Unknown|No|Joy 4 Way|1|2|3|amidar.c|Good|Good|Good|||||||||
|Arkanoid (World)|arkanoid|1986|Taito Corporation Japan|None|None|Breakout|.30|Yes|mame|arcade||Favorite|Raster|Vertical|224x256|3x4|60.000000|Unknown|No|Dial|1|4|2|arkanoid.c|Good|Good|Good|||||||||
|Asteroids (rev 2)|asteroid|1979|Atari|None|None|Shooter / Field|.26|Yes|mame|arcade||Favorite|Vector|Horizontal||4x3|60.000000|Unknown|No|Joy 8 Way|3|1|3|asteroid.c|Good|Good|Good|||||||||
|Asteroids Deluxe (rev 2)|astdelux|1980|Atari|None|None|Shooter / Field|.26|Yes|mame|arcade||Favorite|Vector|Horizontal||4x3|60.000000|Unknown|No|Joy 8 Way|3|1|3|asteroid.c|Good|Good|Good|||||||||
|Astro Blaster (version 3)|astrob|1981|Sega|None|None|Shooter / Gallery|.37b02|Yes|mame|arcade||Favorite|Raster|Vertical|224x256|3x4|60.000000|Unknown|No|Joy 8 Way|2|2|2|segar.c|Good|Good|Good|||||||||
|Bagman|bagman|1982|Valadon Automation|None|None|Platform / Run Jump|.33b04|Yes|mame|arcade||Favorite|Raster|Vertical|224x256|3x4|60.000000|Unknown|No|Joy 8 Way|1|2|4|bagman.c|Good|Good|Good|||||||||
|Battle Zone (set 1)|bzone|1980|Atari|None|None|Shooter / Driving 1st Person|.26|Yes|mame|arcade||Favorite|Vector|Horizontal||4x3|40.000000|Unknown|No|Joy 8 Way|3|1|2|bzone.c|Good|Good|Good|||||||||
|Berzerk (set 1)|berzerk|1980|Stern|None|None|Maze / Shooter Small|.29|Yes|mame|arcade||Favorite|Raster|Horizontal|256x224|4x3|60.000000|Unknown|No|Joy 8 Way|1|2|3|berzerk.c|Good|Good|Good|||||||||
|Black Widow|bwidow|1982|Atari|None|None|Shooter / Field|.26|Yes|mame|arcade||Favorite|Vector|Horizontal||4x3|60.000000|Unknown|No|Joy 8 Way||1|2|bwidow.c|Good|Good|Good|||||||||
And here is my my fearcade.cfg:
--gamelists
gamelist1|favorites/favorites|
--gamelist
favorites|/Favorites/favorites////////arcade/console/Emulaxian/////////////////////////|
And here is my femame.cfg:
--pathnames
emupath|C:\roms\MAME\|
gamepath||
workingdir|C:\roms\MAME\|
sshot|C:\roms\MAME\snap\|
marquees|C:\roms\MAME\marquees\|
flyers|C:\roms\MAME\flyers\|
cabinets|C:\roms\MAME
abinets\|
qtvr|c:\emu\emuarc\mame\qtvr\|
gameinfo|C:\roms\MAME\info\|
glvideodir|c:\videos\|
mame|mame.exe/mame.exe|
emuoption||
altmame||
« Last Edit: September 14, 2002, 10:17:36 am by JesterDEV »
)p(
« Reply #4 on: September 14, 2002, 11:09:00 am »
from your femame.cfg:
this is the commandline the fe will generate for dkong when no other commandline options are set:
c:\roms\mame\mame.exe dkong
is that the path your mame.exe is in? else change emupath to the path were the mame exe is located...
the script error with the tutorial setup
looks ok..strange..I copied your stuff above in a fresh intall and it runs ok...
be sure to set cfg\fewhichselset contains: arcade so the fe nows you are using the cfg\selsets\fearcade.cfg selectionset. Also be sure that you have not wiped out the entry for this set in feselectionsets.cfg that contains a list of all the selectionsets known to the fe...
peter
