Author Topic: smoothmame or equivilent  (Read 2066 times)
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« on: October 16, 2004, 11:45:47 am »
I want to be able to play some of the newer games on a second emulator in Mamewah, but I can't find Smoothmame anywhere..I only have smoothmame32, which doesnt help me when I'm using Mamewah
Is this project dead?
Also are there any other Mame ports that will accomplish the same thing?
When I was using Smoothmame32, I could play the Cruisin's, prop cycle and so on..
thanks
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
Re:smoothmame or equivilent
« Reply #1 on: October 17, 2004, 06:22:17 am »
SmoothMAME is apparently still in development but only updated to version 78. As long as that isn't an issue you can find it here: http://www.zophar.net/mame.html
Hope that helps...
All Your Base Are Belong To Us!
deadmoney5
« Reply #2 on: October 17, 2004, 11:57:50 am »
Thanks for the update!!
Unfortunately, the command line of SmoothMame doesn't work nearly as well as the mame32 version I have ???
Which sux because I am using Mamewah and HATE using Mame32 in my cab!!
Lilwolf
« Reply #3 on: October 18, 2004, 08:00:19 am »
In normal mame, use triplebuffer and you get the smoothness without the speed change.
It really does work well without it.
If your system can't handle triple buffer, thats where smoothmame really helped.  It changes the speed of the game to your monitors refresh... but on many games that changes the speed by 5-10%  (56.333fps -> 60fps makes the game run a bit faster.  And 52fps is a HUGE difference).
