Author Topic: Model 2 in FE?  (Read 1369 times)
liquid8
  • Last login:January 08, 2026, 02:01:16 pm
  • I working on it.. it'll be a while.
Model 2 in FE?
« on: October 15, 2004, 10:43:37 pm »
Anyone been able to get the nebula model2 emu to work from in a frontend. I tried using Howards generic keypress simulator, the only problem was, at the rom selection screen, you cannot press a button to start the rom, you have to mouse click on the start button.
LiQuiD8
  • Last login:January 29, 2026, 09:50:33 pm
Re:Model 2 in FE?
« Reply #1 on: October 15, 2004, 11:38:39 pm »
Heh, you don't need the keypress simulator, you need the command line wrapper.  Nebula takes command line arguments, just be sure to set the gui mode in nebula to classic.
sac01
  • Last login:February 27, 2016, 08:15:22 am
Re:Model 2 in FE?
« Reply #2 on: October 16, 2004, 12:27:23 pm »
Ummm i've had a similar question.. But Howard, i don't see any option either thru the GUI or the INI to set to "classic" for model 2
liquid8
Re:Model 2 in FE?
« Reply #3 on: October 16, 2004, 01:14:06 pm »
The newer version doesn't have the option afaik... I guess until a new release you can use the older version, but i had issues with the classic mode (namely my mouse is not visible, so it is difficult to setup.
LiQuiD8
Re:Model 2 in FE?
« Reply #4 on: October 17, 2004, 05:29:20 pm »
Yes, but the newer version isn't based on nebula and isn't called nebula model 2.  Be careful what you ask for. ;)
