Author Topic: Mame Help  (Read 1308 times)
Mame Help
« on: October 15, 2004, 01:48:57 pm »
OK, I was over at the easyemu site and I was looking at the list of folders that should appear in my mame directory after I unzip it and it doesn't match what they say it should look like.  I don't have the diff, hi, inp, memcard, and sta folders.  I am using the mame087b_i686.zip file from mame.net.
It works fine though but someone here told me to check my mame.ini file and insert the skip_disclaimer and skip_gameinfo commands so I wouldn't have to press 'any key' (Where's the ANY key? I see Esk, Catarl, and Pig-Up. There doesn't seem to be any ANY key ;D) or 'OK' before launching a particular game.  The problem is I don't seem to have a mame.ini file (or mame.cfg) in my mame folder...  Any help would be great.  Thanks!
Wizard of DelRay
Re:Mame Help
« Reply #1 on: October 15, 2004, 02:17:31 pm »
Go to your command prompt and while in your mame directory type:
mame -cc
Now you'll have a mame.ini file.
Wizard of DelRay
Re:Mame Help
« Reply #2 on: October 15, 2004, 02:24:51 pm »
As for the folders, I have a diff folder (but it's empty) and a memcard folder.  The others I don't have but since I don't have any problems with MAME I don't think they're necessary.  For the memcard folder though, do this:
Create a folder called memcard.  Now run a game (I use Puzzle Bobble but any will probably do it) and after you exit out it will have made a file in your memcard folder called memcard.000.
Re:Mame Help
« Reply #3 on: October 16, 2004, 12:28:44 am »
Thanks!  I created the mame.ini file and set skip_gameinfo and skip_disclaimer to "1" and it worked!  I was not able to create the memcard.000 file though.  I only have around 10 roms so perhaps it doesn't work with the ones I have.
Tiger-Heli
    • Tiger-Heli
Re:Mame Help
« Reply #4 on: October 16, 2004, 01:17:53 pm »
Get the hiscore.dat file from http://www.mameworld.net/highscore/
Unzip it to your MAME folder.  Create a /mame/hi folder.
Now MAME will save your hi scores for most games.
