Author Topic: Help with mounting computer with out case  (Read 2092 times)
acasualtourist
  • Last login:April 18, 2017, 10:27:10 am
  • Is this Hell or Ohio?
« on: October 13, 2004, 11:50:12 pm »
I have a smaller arcade cabinet, that the computer, in it's case won't fit in it.  I know the easy way is to buy a bigger cabinet ;D, and the easier way is to buy a smaller case, but I'm poor and would rather spend the money on a marque or side art.  So I figure I'll just put it in without the case.  I know to use standoffs for the mother board, but I'm wondering what I should use to hold everything else(CD-drive, hard drive, etc..).
Also I plan on putting a sub-woofer in the cabinet.  It's a set of old computer speakers so it's not that big, 4" or so.  I can get the motherboard and hard drive about 2' away.  Do you think that's enough?  Do you think there is any difference between the two presidential candidates?   Do you think George Lucas will ever release the UNEDITED version of Star Wars III-IV-V?  OK, maybe I'm getting out of hand here...
Thanks in advance,
Acasualtourist
Hoagie_one
  • Um....whats a cabinet
Re:Help with mounting computer with out case
« Reply #1 on: October 14, 2004, 12:14:57 am »
i bought a pack of mini bungie cords from big lots....they hold most of my stuff down that isnt screwed into something.  Or y ou could just cut off drive bays from your case to mount that stuff as well
SteveJ34
  • Last login:January 06, 2024, 12:29:40 am
« Reply #2 on: October 14, 2004, 12:17:39 am »
There are many different approaches to accomplish this. Someone made a similar inquiry in the Buy/Trade/Sell forum recently to which I responded.
I was in the process of clearing out old stuff and needing an excuse to "create something".
I took an old AT case, removed cover, and got busy with my dremel with a cutting wheel. Basically, cutting frame below 5.25 drive cage, then cutoff bottom of case, drilled some holes, reattached bottom to the shortened frame. The end result was a 3 slot mounting frame for CD, HD, and Floppy (w/ 3.5 to 5.25 adaptors) and a place to mount power supply per norm right behind.
He was going to post a pic when he got a bit further in his project.
Just an idea, perhaps a bit overboard.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #3 on: October 14, 2004, 12:24:31 am »
im just using a motherboard tray to mount the mobo, then velcroing everything down, like the HD, CD drive, ect..
that way it can be removed easy for moving and i dont have to jam a full size case in it..
Hoagie_one
« Reply #4 on: October 14, 2004, 08:11:28 am »
VELCRO, now thats smart
Lilwolf
« Reply #5 on: October 14, 2004, 08:47:59 am »
If you have any cards, that will be your only problem.... keeping them down.
But I'm assuming that you have a WOOD cabinet... If so, you don't need standoffs... You can find them, but don't need them.
I used to use the box my motherboard came in (it was the right size).  This raised it just high enought for cards to fit in the back (and the bottom of the card fit in the slot on the side of the box).  This kept it in place....  Finding a location for the powersupply and drivers always seems to be the problem.  Since a case puts them over your computer... and you probably cant do that.
captainpotato
  • Last login:November 11, 2016, 06:10:59 am
  • I'm a tapir!
    • Tapir Design
« Reply #6 on: October 14, 2004, 08:59:02 am »
Except if there's too much heat near it and the glue melts. I haven't had this happen in a cabinet, but if it happens, it's a real pain.
whammoed
  • Last login:March 06, 2026, 02:40:57 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #7 on: October 14, 2004, 09:15:26 am »
I used standoffs for the MB and aluminum angle and flat bar for everything else.  Check it out if you like:
http://web.tampabay.rr.com/whammoed/whammocade/whammocade.htm
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« Reply #8 on: October 14, 2004, 10:14:25 am »
SteveJ34 - I am still going to post up some pictures, but life has gotten VERY busy lately and I haven't actually installed it yet.  Hopefully within the next couple of weeks!
daeven
  • Last login:July 15, 2022, 12:17:33 pm
  • Llama this!
« Reply #9 on: October 14, 2004, 10:15:25 am »
I like the idea of the aluminum angle pieces.  I've always used scrap pieces of piano hinges with a chunk of rubber underneath the hinges.  This reduces hard drive and CDROM vibration transmission to the rest of the cabinet.
SteveJ34
« Reply #10 on: October 14, 2004, 12:14:27 pm »
No problem. I wasn't moanin' nor do I need any "attaboys".
You're talking to a single dad with three kids and a GF with two more so I definitely understand how life can get busy.
There's never enough time to work on the things to the degree that we would like to.
Good luck and continued success on your project.
acasualtourist
« Reply #11 on: October 14, 2004, 05:19:27 pm »
Thanks for all the good ideas.  I really like Whammoed's card brackets.  (and the cabinet kicks @ss)    Also with the velcro, has anyone actually had the glue melt on them or is that just a fear?
captainpotato
  • I'm a tapir!
    • Tapir Design
« Reply #12 on: October 17, 2004, 10:07:39 am »
Only in my car, but in shade in winter, which is why I'd be cautious, given the heat that some machines now put out.
