Author Topic: Need advice please - which TV ?  (Read 1213 times)
barvaz
  • Last login:May 24, 2006, 11:36:21 am
  • Ugh
« on: October 12, 2004, 04:07:20 pm »
I am starting to shop around for a used TV for my upright cabinet now. I figured I
« Last Edit: October 12, 2004, 04:08:49 pm by barvaz »
Hiub
  • Last login:October 14, 2004, 10:06:04 pm
Re:Need advice please - which TV ?
« Reply #1 on: October 12, 2004, 05:21:51 pm »
A 27'' TV will work great for an upright cab, and even something bigger, like a 29'' will be ok. I am using a 27'' TV for mine, and it is about 24.5'' wide.  I believe with a 28'' inside width, you could fit up to a 32'' without problems, but ALWAYS double check that the monitor will fit. S-Video is a must, as the picture quality is increased dramatically. In my opinion, a flat screen TV does not belong in a cab, and I believe that the regular rounded tube will give you better results anyways. Just make sure you buy a quality TV, as the picture can vary greatly from a no-brand tube and a well known company.
Hope this helps, Fred.
barvaz
  • Ugh
« Reply #2 on: October 16, 2004, 03:54:23 pm »
Thanks for the response.
Most of the new 29
« Last Edit: October 16, 2004, 03:56:10 pm by barvaz »
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Reply #3 on: October 16, 2004, 10:05:56 pm »
Personally, I think 27" (what I'm using) is a bit too large for a number of games. It's fine for some, but games where you'd like to keep track of everything onscreen at once (robotron comes to mind) suffer. I would use a smaller screen if I had this project to do over again.
