Author Topic: Display on Eygo monitor inverted  (Read 2670 times)
cnlc
  • Last login:September 12, 2002, 02:34:25 pm
« on: September 11, 2002, 05:50:00 pm »
I just picked up an 19" Eygo monitor and the picture is inverted like you are looking at it through a mirror.
Any idea on how to fix this.
TIA.
MameFan
Re:Display on Eygo monitor inverted
« Reply #1 on: September 11, 2002, 06:24:39 pm »
If you mean from top to bottom it's okay, but left->right is messed up, then it sounds like your Horizontal Yoke wire is swapped.
The yoke wires should connect from the yoke to a removable connector on the main chassis board.
The connector looks sort of like this (as best as ASCII art can do)
If the colors used are the same as industry standard, they should be in this order, per the above picture:
Brown White Grey Red
If the connector doesn't have a wider pin at the right, it may have the following colors:
Red Blue Yellow Green
You need to swap White/Red wires (first connector) or Blue/Red (second connectors to reverse the way horizontal is drawn.
A VERY COMPLETE description of this, the dangers (NEVER mismatch the connectors if you're not sure, you will end up frying the yoke or board or something else more important (you) if you dont know what you're doing), read the following page at TheRealBobRoberts.Com
http://www.dameon.net/BBBB/yoke.html
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
« Reply #2 on: September 11, 2002, 07:15:29 pm »
i saw the guy on ebay selling eygo 19" monitors..
and he explained the whole matter...
i think there is 2 molex looky connecter but dont take my word as i dont know much about how monitors work.
stick with mamefan and change whatever needs to be changed.the guy at ebay had pictures too..
who did you buy it from?
you can email the guy and see if he knows..
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: September 11, 2002, 08:02:59 pm »
Check your PM
cnlc
« Reply #4 on: September 13, 2002, 04:45:14 pm »
Thanks to for the help.  Switched the connectors (a few times) and finally got the proper display.
You guys are great.
