Author Topic: SUBWOOfers+HI FI ANALOG AMPLIFIER  (Read 2517 times)
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
« on: October 04, 2004, 07:30:39 am »
HELLO!
                I have JVC an early 87's 200 watts hi fi AMP.
I have already attach it with my PC enjoying it.
speakers are two channels.8"inch 8 ohm and 80 watts.
but it is an old due to which it,s speakers are also very old.
recently i have repeared both of the 8"inch speakers.
Now i want to replace these speakers.
Can i attach 8 or 10 " sub woofers with the amp...
The main reason for doing this is to make a powefull
bass boost sound system .
any advice here for the type of subwoofers.
with thier Ohm's and watts..
thanks in advance...
BLUE BIRDS FLY WITH BLUE BIRDS
Crazy Cooter
  • Senator Cooter was heard today telling the entire congressional body to STFU...
  • Last login:August 19, 2025, 11:29:13 pm
Re:SUBWOOfers+HI FI ANALOG AMPLIFIER
« Reply #1 on: October 07, 2004, 04:38:24 pm »
So you're asking if you can just replace the 8" woofers with 8" "sub"woofers?  Yes, you can.  Easiest way is to just drag the old speaker box with you to wherever you're buying the new ones and have them help.  They can tell you what will work best.
There's several things you need to consider if you're going to upgrade a raw driver in a box.  Driver size, Ohm load, crossover frequencies, response curves, etc.  That's why it's best to just bring it in unless you know most of these factors.
KHAN
« Reply #2 on: October 20, 2004, 05:48:10 pm »
You told me the manual method of replacing my speakers.
it is not a child's play.
