Author Topic: Smartstrip to Shut Down Everything  (Read 1907 times)
dmish82
  • Last login:September 09, 2005, 10:31:40 am
  • "What is this? A center for ANTS?!?!?!"
« on: October 01, 2004, 11:13:29 am »
Hi,
I saw a post which had a link to a Smartstrip which can be used to shut everything down. I was wondering what your thoughts are on this one (good or bad luck) and whether anyone's tried any other ones (cheaper/different brands, etc) and your luck with those.  Do you think this is the easiest route to go to get everything to shutdown? Thanks.
Hoagie_one
  • Um....whats a cabinet
Re:Smartstrip to Shut Down Everything
« Reply #1 on: October 01, 2004, 11:21:31 am »
i think this is your best bet and it should work 100% of the time
http://www.thinkgeek.com/gadgets/electronic/6ee4/
That or build your own relay like i did
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« Reply #2 on: October 01, 2004, 11:42:41 am »
I love my smartstrip. It shuts donw everything with one button press. I just wish it would turn my TV on, but that's not an issue with smartstrip. It's an issue with my TV.
I would highly recommend it to anyone.
krick
  • Gotta have blue hair.
« Reply #3 on: October 01, 2004, 11:44:49 am »
As an alternative to the smart strip option, you could get a Vantec ION power supply.  It has an "accessory outlet" on the back that switches on and off with the PC.
More info in this thread...
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=20611
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
RecycledPast
  • Last login:October 09, 2011, 09:14:47 pm
    • My 2 scratch built arcade machines
« Reply #4 on: October 01, 2004, 11:50:05 am »
This topic has been addressed many times before.
Here is my personal experience.
I have Smart Strip LCG1 ($29.95) + s/h
http://www.bitsltd.net/smartstrip/buy.htm
It works correctly at home but when I bring my bartop to work I can't get it to work correctly, it's as if the sensitivity dial needs to be more sensitive. I think that this problem also might have something to do with my very old P2 computer.  Another downside is that it's really big and I didn't take that into account when building my bartop.
I've removed it from my bartop and plan on trying it on a different computer to see if it works any better.
I replaced the smartstrip with a sears Craftsman Auto Switch  ($19.99)
Sears item #00924031000 Mfr. model #24031
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00924031000
It worked perfectly out of the box, the downside is that it only had 3 outlets and it needs an extension cord.
Extension cord ($3-$8).  I also needed another outlet (pc, monitor, speakers, light) so I bought a Power Strip Liberator II PL3 from bitsltd ($3)so I would have enough outlets.
In the end they were similar in price ($35ish).  The sears device is not a surge protector, but it is smaller.
