Author Topic: RAM/memory question  (Read 1599 times)
johnnysmitch
  • Last login:November 16, 2006, 02:22:05 pm
  • I want you to MAME me as hard as you can
RAM/memory question
« on: October 01, 2004, 10:17:23 am »
I recall reading on here something about ram getting bogged down after playing multiple games in mame, and some kind of setting that clears your memory every time you close a game, instead of every time you reboot (or at least something along those lines) - as you can tell, I can barely word it well here, so searching the boards for my answer has been pretty unfruitful - anyone know what i'm talking about/how to do it?
daywane
  • GRRRR!
Re:RAM/memory question
« Reply #1 on: October 01, 2004, 12:18:21 pm »
why...?  are you having a problem. I have not run into this... but all my mame machines are XP  and as far as I can tell XP clears the memory.
I did have problems with windows ME but it was not just Mame. heck just sitting there memory would run out in Windows ME
« Last Edit: October 01, 2004, 12:19:02 pm by daywane »
johnnysmitch
« Reply #2 on: October 01, 2004, 01:27:38 pm »
yeah, my games seem to be running a bit slower as i play more during a session - maybe its partly because i'm running mame32 right now?
whammoed
  • Last login:Yesterday at 12:42:21 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #3 on: October 01, 2004, 02:30:37 pm »
what operating system are you using?
Darkstalker
  • Last login:June 27, 2010, 12:55:36 am
  • A legend in my spare time...
« Reply #4 on: October 01, 2004, 03:02:52 pm »
That's known as a "memory leak".  Do a search for "RAM recovery" programs and I'm sure you'll come up with a host of applications that will auto-scan and recover RAM when it passes a certain percentage in use.
Have you tracked your RAM usage on the system?  That would be a tell-tale sign if there is a memory leak involved.
Still in the collecting parts and ideas phase of cabinet building.
johnnysmitch
« Reply #5 on: October 01, 2004, 03:54:56 pm »
I'm using XP Pro.  Also, to give some more info, my system is an Athlon 2000+ w/512 megs 400mhz ram (temporarily borrowed from my main system).  I'll look into that memory leak thing, thanks!
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #6 on: October 01, 2004, 05:57:32 pm »
Perhaps this will help?
http://www.aldostools.com/freemem.html   This program can free memory when it hits a certain low point.
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
« Reply #7 on: October 01, 2004, 06:46:40 pm »
Dont take medicine by your self.
take a doctors advise. ;)
Your hardware information you have mentioned is quite
good for play most of the games in mame ecept of a Noami
emulation 3D games...
Try to keep configuration settings again.
In my advise use windows98 for using mame32...
BLUE BIRDS FLY WITH BLUE BIRDS
