Author Topic: Nebula in Mamewah  (Read 1266 times)
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
Nebula in Mamewah
« on: September 30, 2004, 01:21:54 pm »
I've had this problem for a couple of months now - I think I've been ignoring it, hoping it'd go away, but it hasn't!
I've got Mamewah working totally fine with the others Emus I'm using, and Nebula is working great if I just start the .exe from Windows, no problem.
Here's what happens in Mamewah:
I select 'Neo' in my menu (For Nebula)
The games list loads fine, no problem
I click on a game
It goes into the loading screen for a split second
Back comes the menu in Mame exactly as it was a second ago.
I've treied messing with the settings in the Mamewah config file for Nebula, and with the 'VIDEO' settings in Nebula when run from the .exe in Windows.
I can't figure it out - even narrowing it down to a setting in Mamewah config, or a setting in Nebula would be progress. Common sense says if it works from the .exe in Windows, then it must be the way Mamewah is accessing it, unless it's a quirk of some other description. Anyone got a fix?
Tony
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
Re:Nebula in Mamewah
« Reply #1 on: October 04, 2004, 06:00:09 am »
Sounds like the commandline being used is incorrect - launch the emu from a commandline to figure out the format, then refer to mamewah.log and edit emuname.ini to duplicate the format.
Halo
  • I'm a lamer!
« Reply #2 on: October 17, 2004, 07:42:03 am »
Thanks Minwah!
Can you tell me how to do that in buffoon-proof steps?
Thanks  ;D
