January 26, 2026, 11:17:52 am
Sorry, forgot to add. I'm tired of fishing out the keyboard for the OK screens in mame. Not the ones you can disable in the .ini files but the ones stating that the colors or sounds may not be just right. What do I need to do for this as well?
Quote from: iamnaeth on September 30, 2004, 12:16:47 pmSorry, forgot to add. I'm tired of fishing out the keyboard for the OK screens in mame. Not the ones you can disable in the .ini files but the ones stating that the colors or sounds may not be just right. What do I need to do for this as well?Waggle the P1 joystick left/right a few times.
Good, because then it would not work. Remap your p1 left-right ( or p2, or any two buttons) to "O" and "K". Then you just have to use the appropriate joystick/buttons to enter the necesary "OK"Otherwise you need to hack the MAME source code and re-compile it.Better to just re-map.Best place I found to keep up to date on new/changed ROMS is to use the program Rom Center to manage them and the news groups to get the necessary updates. -wj2k3
