Author Topic: Screen Rotation for ExciteBike  (Read 2356 times)
Renegade
  • Last login:June 25, 2003, 01:43:27 pm
« on: September 09, 2002, 09:47:18 am »
I have a problem with rotating the screen 90 degrees for ExciteBike.  I use MAME32 0.58 and have a cocktail cabinet with the controls opposite the shoter sides of the monitor.
This means for most games I rotate the screen 90 degrees, and it works fine for them.
However, ExciteBike works fine in it's normal horizontal layout but when I rotate it the graphics get screwed up.  The time/fuel meter are all wacky as well as the biker.
Anybody know of a fix for this or am I just out of luck playing it on a cocktail?
Thanks.
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
Re:Screen Rotation for ExciteBike
« Reply #1 on: September 09, 2002, 09:58:38 am »
upgrade your mame to .61. They changed to using hardawre blit rotate from your vidcard...that will solve this problem. Some drivers did not like the old way...vsnes.c and neogeo.c for example...
(If you want to use a mame before blit rotate wass added you can use advance mame. It has had this feautere for a very long time...)
Peter
Renegade
« Reply #2 on: September 09, 2002, 12:34:23 pm »
Peter
Thanks Peter, i'll give that a try.
