Author Topic: drilling metal control panel  (Read 3844 times)
rob1234
  • Last login:September 23, 2022, 07:40:58 am
« on: September 28, 2004, 01:16:02 am »
What should I use to drill button holes in a metal control panel? Also, does anyone know where I could get a solid black control panel overlay?
Mameotron
Re:drilling metal control panel
« Reply #1 on: September 28, 2004, 05:44:29 am »
Fastest way to cut holes in metal.  Guaranteed. ;D
http://www.mylincolnelectric.com/Catalog/equipmentdatasheet.asp?p=456
Seriously, if you can't afford $3500.00 a bi-metal hole saw will do.  Make sure the panel is REALLY solidly clamped down.  And watch out for the bit catching and spinning the drill out of your hands.  Will NOT work with a cordless drill.
http://www.grizzly.com/products/item.cfm?itemnumber=H0884
« Last Edit: September 28, 2004, 05:45:34 am by Mameotron »
Hoagie_one
  • Um....whats a cabinet
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #3 on: September 28, 2004, 09:04:46 am »
I have made many, many button holes in both plate steel and aluminum.  I use 1 1/8" bi-metal hole saws.  It takes a while w/ steel but it works.
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
brained
  • Last login:October 07, 2025, 10:17:53 am
  • Raised by Atari
    • Nux
« Reply #4 on: September 28, 2004, 09:37:23 am »
If you wan't a solid black control panel overlay just buy some vinyl from parts express (http://www.partsexpress.com) they sell a good overlay and it's quite cheap.
You can also use black contact paper or else just paint the darn thing!! :P
fatbasta
  • Last login:June 26, 2005, 02:27:36 am
  • Fatbasta!
    • Time Warp - Jimmy Ray's MAME Aracde Project
« Reply #5 on: September 28, 2004, 11:02:23 am »
I didn't have much luck.  I burnt up 1 hole saw, should have used lube of some kind, twisted the shaft off of 2 rotary files and my hi torq Dewalt nearly ripped my arm off twice. I gave up and cut one out of 3/4 MDF.  With a few coats of black enamel It looks just as good as the original.  I hope you have better luck.
whammoed
  • Last login:Today at 10:55:04 am
  • Crack don't smoke itself
    • NiceMite
« Reply #6 on: September 28, 2004, 11:09:34 am »
Did these with bi-metal holes saws for everything 1 1/8" and larger and used a step bit for the smaller holes.  All bits and saws are still in good shape.
durak
  • Last login:September 03, 2010, 06:49:14 am
« Reply #7 on: September 28, 2004, 12:57:23 pm »
Considered having it made instead of making it yourself? I just cut out rectangles on the original panel where the buttons are, and bolted the one made at a workshop on top of it. Looks very nice, and only cost me 20 euros (around 25$ I guess) so it's less than all those fancy tools needed for doing it yourself. Just need to find a relatively small shop that will bother with doing it for you.
Minwah
    • MAMEWAH
« Reply #8 on: September 28, 2004, 01:57:17 pm »
I'd highly recommend a hole punch.  I bought a relatively cheap one and it worked wonders for me (admittedly it probably won't last as long as a more expensive one, but I won't need it much).
johnnysmitch
  • Last login:November 16, 2006, 02:22:05 pm
  • I want you to MAME me as hard as you can
« Reply #9 on: September 28, 2004, 04:51:40 pm »
I've found that when you're using a hole saw to cut through sheet metal, it's usually better to go slower RPM with a lot of force than to use the highest setting, as you can keep better control, and can back off right away if the bit starts to snag, which can result in a hell of a tweaked arm.  And if you're planning to drill through stainless, going slow with a lot of force is the only way to even drill the hole, as going fast will heat-temper the stainless, and then you'll never get through it with a drill.  BTW, if you're using a cordless drill (I drilled many holes in stainless with an 18v dewalt), just make sure to let the drill rest adaquetly between holes, or you're gonna burn out the motor.  This applies to any drill really, but cordless ones seem to burn up alot faster...
Tailgunner
  • Last login:October 06, 2009, 01:21:16 pm
« Reply #10 on: September 28, 2004, 05:28:59 pm »
This is faster, plus it'll punch cleaner holes than a Greenley knockout punch. ;)
http://www.rotexpunch.com/rotex_hand_punch_presses.html
