Author Topic: Fan speed selection  (Read 1053 times)
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
Fan speed selection
« on: September 27, 2004, 07:57:33 am »
Hi all,
I'm fitting a coolermaster fan to my cocktail cab to extract the hot air. It's fairly noisy and need to switch it to low speed operation. Just wondering how to do this. If I connect the yellow wire to the red one will this select low speed op on the fan?? It's connected to the PC via a 4 pin molex adapter
Dexter
seibu
  • Last login:March 28, 2007, 12:55:34 pm
Re:Fan speed selection
« Reply #1 on: September 27, 2004, 09:03:12 am »
Hello,
I recently had the same dilemma with another fan. I'm not sure of the details of how your fan connects to the PC, but what I did was to simply connect my fan between the red and black wires coming from the PC power supply rather than the yellow and black, so it ran at 5v instead of 12v.
Other solutions suggested to me included putting a resistor in line with the yellow wire, to reduce the voltage and hence the speed, or even a potentiometer so I could adjust the speed. Hope this is some help.
wj2k3
  • Last login:August 22, 2006, 12:23:48 am
  • Not!
« Reply #2 on: September 27, 2004, 09:55:53 am »
You could also hook the fan to the yellow and red wires for 7 volts.   (12-5=7)  This will give you more speed than the 5-volts but less noise than the 12-volts. (obviously)
-wj2k3
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #3 on: September 27, 2004, 08:30:06 pm »
You could get a fanbus too.  They make 'em to fit drive bays and you could dial it down to a tolerable level.  Going that route, follow their directions.
wrxh8r
  • Last login:April 02, 2008, 11:30:49 pm
  • idiot extraudineer
« Reply #4 on: September 27, 2004, 09:14:25 pm »
zalman fanmate is a cheapish option
Your never alone with a rubber duck
Dexter
« Reply #5 on: September 28, 2004, 05:19:29 am »
Connected the fan to red wire instaed of yellow as detailed above, worked an absolute treat. Thanks as always everybody!
Dexter
