Author Topic: mame 55 speed issues  (Read 1641 times)
bigle
  • Last login:August 10, 2006, 02:22:54 pm
  • i may or may not be a llama
« on: September 26, 2004, 01:17:36 am »
i've seen it mentioned that you could run neo geo games at full speed on a 500 mhz machine using mame 55.  since i'll be using an p3 800 in my cabinet i figured i'd check it out.  so far messing around with it on my laptop (1.2 ghz celeron) the best i've been able to get is 35/60 on the couple of neo geo games i've tried.  what kind of settings do i need to use to increase speed.
thanks
who fishes with cheese?
spystyle
Re:mame 55 speed issues
« Reply #1 on: September 26, 2004, 08:23:11 am »
Have you tried fastmame?
http://www.geoshock.com/
« Last Edit: December 09, 2006, 09:55:26 am by spystyle »
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
« Reply #2 on: September 27, 2004, 01:50:25 am »
Have you read the mame help file?
In which a written requrement to run Mame.
When MAME55 released,the neogeo roms was not fully updated and were use as they were in neogeo emulator.
I know that 500 mhz with 128Mb RAM are enough to run these games.You have to be carefull because speed of any game require a hardware to be fully emulate.Fastmame is an emulator which is desingn for such type of metters.
BLUE BIRDS FLY WITH BLUE BIRDS
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #3 on: September 27, 2004, 05:53:55 am »
thanks
Are you testing DOS Mame or Mame32 on that laptop? I would imagine that DOS Mame would give you better performance with v0.55.
I've found that Mame32 needs to have its settings tweaked on almost every computer I put it on, depending on what version of Windows and what video card its using. I have a 500Mhz Celeron laptop with Mame32 v0.72 running classic games, I'll try some NeoGeo's when I get home and see how it goes.
bigle
« Reply #4 on: September 27, 2004, 03:10:30 pm »
i tried fastmame and it's almost perfect.  one of the conditions i have on getting to put the arcade cabinet in the house is ms pac man.  specifically the fast ms pac man.  i tried enabling the cheat.dat but fastmame has a 2x speed increase instead of the spead hack that regular mame had.  is there any way to add the speed hack to fastmame?
i read through the faq and .txt files and the only mention of speed i could find was a 700 w/ 128 megs of ram.
i haven't tried out the dos or 32 versions of mame yet.  from browsing the boards it seemed like a general consensus was that mame 55 was the way to go for older/slower machines.  i think it was peale or paigeoliver who said you could run the neo geo games full speed on a 500 with it.  when i tried it out i still couldn't get 60/60 so i figured i'd ask to see if there was some setting i was missing.
« Last Edit: September 27, 2004, 03:43:47 pm by bigle »
