Author Topic: trouble with 360 stick/psx hack  (Read 1080 times)
IguanaStorm
  • Last login:December 21, 2020, 10:50:25 pm
« on: September 25, 2004, 03:32:46 pm »
i got all the buttons to work but when i hook any direction up to the 360 stick it acts like its grounding out.  for example when i load up a game and if i only have left hook up to the 360 stick, than the game acts like im holding left.  there is no solder touching the ground side of the D pad contact.  any ideas???
IguanaStorm
Re:trouble with 360 stick/psx hack
« Reply #1 on: September 25, 2004, 03:52:14 pm »
one more thing... im sure its the 360 stick because when i un hook the 360 stick and just leave the pad plugged in it does not hold left.  i know the stick worx because i used it with a different pcb.
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
« Reply #2 on: September 25, 2004, 04:30:32 pm »
not that i know alot about this topic but i'm having problems also
check your +v connection.. without +5 hooked up, the joystick connection always looks like it's on
my +5 psx hack wire  didn't work so i hooked it up to another source and it worked
IguanaStorm
« Reply #3 on: September 25, 2004, 04:37:33 pm »
what type of power source did you use????
mcdo15
« Reply #4 on: September 25, 2004, 05:04:33 pm »
i have an ipac i'm going to use
(for admin buttons and dedicated 4 way)
over kill but hey..what can i say
IguanaStorm
« Reply #5 on: September 25, 2004, 05:07:54 pm »
the ipac has a power source?
mcdo15
« Reply #6 on: September 25, 2004, 07:32:51 pm »
http://www.ultimarc.com/ipac2.html
looks toward the bottom ....
there should be 9 pins (1 missing for ground)
right above where you plug in wires
i stole it from there
if you have an ipac ve, +5 has it's own connection at end
