Author Topic: I-Pac keystrokes repeating  (Read 918 times)
Brocken
  • Last login:December 21, 2004, 08:05:59 am
« on: September 24, 2004, 12:03:08 pm »
I've wired everything up and all the buttons and the player 2 joystick work, but when I try and use the player1 joystick it keeps repeating left, right, up or down indefinately when I click the direction once.
Anyone know how to fix this? :(
Hoagie_one
  • Um....whats a cabinet
Re:I-Pac keystrokes repeating
« Reply #1 on: September 24, 2004, 12:08:21 pm »
thats the second time in as many days that someone had this problem with an ipac
strange
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Reply #2 on: September 24, 2004, 09:50:36 pm »
I'd double check the wiring on joystick 1 to make sure there isn't something wrong e.g. some bare wires touching each other that shouldn't be.  If you can't find anything post to the Ultimarc Main Message Board link via their website.  Andy is good about responding.
Brocken
« Reply #3 on: September 25, 2004, 10:24:38 am »
Found the problem now, had the wire hooked up to the wrong connectors.
The NO and NC connectors are switched round on the T-stik :D
