Author Topic: Defender cab help and cab ID assistance.  (Read 1233 times)
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« on: September 23, 2004, 03:51:23 pm »
Yesterday I was lucky enough to ba able topick up 2 cabs from the local Nickelcade for $25 each. They are complete except the coin door locks and the boards.
When I opend up the back of the GUnforce cab There were a bunch of old manuals inside. After I pulled them out I then realized I have an old Defender cab with all of the documents to go with it. The other cab is padlicked and I haven't had time to cut the lock off, but I didn't see anything except papers on the monitor.
What I need to know is what the second cab is and if I should resore the defender cab. The bottom front panel has excessive water damage, but the side panels are OK. It was made out of plywood that needs alot of love to get smooth again.
Would I be better off just mameing both of them or restore them both, since they have pretty much everything I need still there. The second cab has a jamma harness in it too.
Would do the pros think??
« Last Edit: September 24, 2004, 11:52:14 am by clanggedin »
whammoed
  • Last login:Today at 04:07:54 pm
  • Crack don't smoke itself
    • NiceMite
Re:Should I restore these cabs?
« Reply #1 on: September 23, 2004, 03:54:44 pm »
can't see your pics :(
Hoagie_one
  • Um....whats a cabinet
« Reply #2 on: September 23, 2004, 03:55:09 pm »
PICS DONT WORK
clanggedin
  • O'DOYLE RULES!!!
« Reply #3 on: September 23, 2004, 04:01:28 pm »
fixed
Hoagie_one
« Reply #4 on: September 23, 2004, 04:06:49 pm »
hella deal yougot.  the cabs are in pretty good shape.  I have no skills to restore them to the orignal games but that is the common statement here.
save the originals
pointdablame
« Reply #5 on: September 23, 2004, 10:37:01 pm »
How did you NOT know that was a Defender?? hehe j/k
I'm not sure what the other cab is, although I'm sure you'll get a response from someone else here.  If it were me, I would definitely restore the Defender if possible.  Or at the very least, MAME it with a defender CP and run Defender on it with a simple low-end PC.  I just love those cabs, and it would be awesome to have a real Defender IMHO.
first off your and idiot
danny_galaga
  • Last login:Today at 06:25:03 am
    • dans cocktail lounge
« Reply #6 on: September 23, 2004, 11:22:41 pm »
definitely restore the defender
clanggedin
  • O'DOYLE RULES!!!
« Reply #7 on: September 23, 2004, 11:49:21 pm »
I just peeled off the Gunforce sticker and it took some of the glossy black paint that was under it with aloing too. It revealed some of the original artwork. I hope that a heat gun will allow me to peel away the paint and expose the defender stencil.
As soon as someone can help me identify the other cab, then this thread can be moved to the project section. The CP is original too. has the holes cut into it.
Looks like I have alot of work ahead of me if I want to restore the cab.
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
Re:Defender cab help and cab ID assistance.
« Reply #8 on: September 24, 2004, 04:09:21 pm »
  Restoration takes a ton of work.  I'm finished restoring a defender, or at least the cabinet, so taht the original boards could be put in and have it make no difference.  Unfortunately I didn't know about good paint stripping methods and SANDED down the 2-3 coats of paint over the original artowrk off.  Wow, It took somewhere close to 20 hours all told.  It looks great now, but man, I'd recommend against doing the sanding method.  =)
