Author Topic: Momo steering wheel not working properly cuz analog vs digital!  (Read 1460 times)
J-Lu
  • Newbie
  • Last login:September 22, 2004, 11:32:21 am
« on: September 22, 2004, 11:39:43 am »
Anyone know how to setup Logitech Profiler so my new MOMO steering wheel will work with mame games like Pole Position?
I think it has to do with Analog vs Digial, but I can't figure it out.
I just bought a Logitech MOMO Force steering/racing wheel.  Here's what happens:  When I turn to the right, I still drive straight.  When I turn severly to the right, I drive severly to the right and crash.  It's either on or off.  There's no subtle turning!  Can anyone help?  Much appreciated!
J-Lu
Minwah
    • MAMEWAH
Re:Momo steering wheel not working properly cuz analog vs digital!
« Reply #1 on: September 22, 2004, 11:54:49 am »
Try adjusting the sensitivity in MAME (Tab > Analog Controls).
It probably doesn't help that Pole Position used optics (360 degree wheel) originally.  These type of games usually don't play well with pot-based wheels (all pc-wheels).
NoOne=NBA=
« Reply #2 on: September 22, 2004, 08:20:39 pm »
Basically this question is the same as "How do I make a joystick play trackball games?".
You may be able to PLAY Pole Position with the MOMO wheel, but I don't think you'll get it to be really enjoyable.
The places I would start are:
1) Open the joystick config in Windows, and move the wheel very slightly when it asks you to run the "full" range of the joystick axis on it.
This should get it to read "barely left" as "all the way left", and "barely right" as "all the way right".
2) Set the key/joy settings down from what they are now in MAME using the arrow keys to turn.
That should keep the car from hooking right when you hit the "I'm to the right" spot on the stick.
The one downside to this is that releasing the joystick will not bring you back to the left (to go straight), like you would think, it will merely stop the car from turning any farther right.
You will have to pass center, and go left to bring the car back to a straight direction.
This is because the original 360 wheel is set to detect motion, rather than position, like the 270 wheel you are using.
3) Continue to play with the settings until they feel as good as you can get them, and then see if you are OK with them.
My guess is that you won't be, but it might be OK for you.
There really is no substitute for a 360 wheel in 360 games though.
Basically, what you are doing by adjusting the stuff I suggested is turning the 270 wheel into a digital joystick.
Xiaou2
  • Last login:Yesterday at 07:12:23 pm
  • NOM NOM NOM
« Reply #3 on: September 22, 2004, 10:17:24 pm »
exactly.
  Youll need a spinner to play this game correctly.
 I highly recomend one, as the spinner games are well worth the aditional cost.
 An analog pot based wheel can not replicate the games playability.  It will be fusterating, lacking in controllability,  and 1000 times less fun.
Minwah
    • MAMEWAH
« Reply #4 on: September 23, 2004, 05:44:04 am »
exactly.
But excellent for OutRun and the other ~270deg wheel drivers :)
