Author Topic: ArcadeVGA Resolution Tool PROBLEM *******  (Read 1029 times)
koolmoecraig
    • My Intervention
« on: September 20, 2004, 08:28:39 pm »
Hello,
When I first set everything up it worked perfectly. It generated the ini files and everything worked great. Then I was trying out games and noticed that basically every vector game "rolls" on me. So I went to check the INI files and I can't find any INI files for the vector games. I tried to run the ArcadeVGA Res Tool again so I could set the resolutions and it will not generate any files at all for me to tweak, vector or not.
What could I be doing wrong here?
Thanks,
Craig
koolmoecraig
    • My Intervention
Re:ArcadeVGA Resolution Tool PROBLEM *******
« Reply #1 on: September 20, 2004, 09:21:52 pm »
Don't be shy!
