Author Topic: Karate Champ Control Setup  (Read 1566 times)
Rapid Axlr8ion
  • Last login:September 24, 2004, 02:09:55 am
  • When in doubt...Whip it out!!!
« on: September 19, 2004, 08:07:42 pm »
Hello...Can anyone help me setup the controls for Karate Champ?  I am using the most current version of MAME and am noticing in the control setup that there aren't enough "options" to configure my two joysticks to emulate the real arcade game.  I need to be able to do: up/up, up/down, down/down and down/up and those options are not available, from what I can tell.  I am probably missing something very simple on this one, but please help if can.  Thanks
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
Re:Karate Champ Control Setup
« Reply #1 on: September 19, 2004, 08:34:09 pm »
You use two joysticks for this game.  Up/Up means both the 1st and 2nd joystick are up.  If you want to do 2 players (which is a lot of fun) you need 4 joysticks.  Yikes.   :)
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
Rapid Axlr8ion
« Reply #2 on: September 19, 2004, 08:41:26 pm »
Yeah...I understand the movement of the joysticks and realize that I need 2 for one player and 4 for two player.  However, my "Setup" only gives the options to configure for: Left/Up, Left/Down, Left/Left, Left/Right...Right/Up, Right/Down, Right/Left, Right/Right....There is no option to do Up/Up, Up/Down, Up/Left, Up/Right and Down/Up, Down/Down, Down/Left and Down/Right...That is where I need help.
Apollo
    • Eight Bells
« Reply #3 on: September 19, 2004, 09:23:33 pm »
WTF?
telengard
    • S T U R C A D E
« Reply #4 on: September 19, 2004, 09:53:02 pm »
When it says "Left up"  that's the equivalent of the *left* joystick moving up.  You don't have to do every combo.  So there should be 8 entries.  4 for each joystick (per player)
Rapid Axlr8ion
« Reply #5 on: September 19, 2004, 10:02:23 pm »
Duh....
I knew it was something simple...I thought I had to program every combo...Thanks :-)
