Author Topic: how to wire GT trackball GND connections?  (Read 842 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: September 17, 2004, 10:13:05 am »
the golden tee trackball has two green wires that need to be connected to an earth point. think it is to disipate any static electricity from the rolling balls. i think it would normally be connected to an earth point on the chassis of the GT cab. but i am using the TB in a all wooden CP.
is it absolutely necessary to be connected to GND?
can i connect to GND connection on my optipac? or will it cause damage?
GGKoul
  • Cheesecake Apprentice
Re:how to wire GT trackball GND connections?
« Reply #1 on: September 17, 2004, 11:11:21 am »
I connected mine to the bottom of the trackball plate.  No issues.
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
« Reply #2 on: September 18, 2004, 02:24:21 am »
All grounds in a cab are connected to the same thing--ground.
It should be fine to connect it to any available ground, but if you're afraid it might damage something, just put a resistor in series to prevent voltage spikes.
Any low value will do (eg, 100 ohms)
