Author Topic: Trackball Template  (Read 1018 times)
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
Trackball Template
« on: September 16, 2004, 11:59:37 pm »
Can anyone give me a template for mounting a imperial 3" trackball?
I will not be using a mounting plate, so I need to know where to drill the 4 holes (plus the big hole).
brained
  • Last login:October 07, 2025, 10:17:53 am
  • Raised by Atari
    • Nux
Re:Trackball Template
« Reply #1 on: September 17, 2004, 08:47:55 am »
I suggest you to open your trackball and use the top part to mark your holes. That's how I'm going to do it!, I own an Imperial Trackball.
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #2 on: September 17, 2004, 10:24:44 am »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: September 17, 2004, 01:35:03 pm »
Imperial, wico and happs follow the industry standard for the hole locations and hole sizes.*  The Imperial and wico cases are bigger than the happs/atari cases, though.
Check out mounting plate dimensions and happs case size for sizes, but nothing's as good as the actual thing, as brained suggested.
*except for happs hall ball model.  The other models, high lip, GT, high rim, and normal all use the the same.
Robin
Knowledge is Power
