Author Topic: Building Mame cab - stuck - any ideas??  (Read 1429 times)
pvfoy
  • Last login:September 15, 2004, 03:04:26 am
« on: September 14, 2004, 11:20:50 am »
I've got my cab, jpac, arcadevga card and computer all wired up.
All lights illuminated on jpac.
But just getting a blue monitor that ripples a little when i hit the 2 player button!!??
any ideas pleeeeeeeeeeeeese
it's driving me mad - i want to play gorf!!
i've ordered a pcb to test the monitor but it hasn't arrived yet
the guy who sold me the cab said it was working fine?
thanks
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re:Building Mame cab - stuck - any ideas??
« Reply #1 on: September 14, 2004, 10:52:23 pm »
What software is running?
Did you try forcing MAME to use a low resolution, like 320x240?
NO MORE!!
pvfoy
« Reply #2 on: September 15, 2004, 03:05:36 am »
using xp
but not even getting the bios screen on the monitor on startup so can't even get as far as mame?!!
cdbrown
  • Bowowow
« Reply #3 on: September 15, 2004, 03:22:08 am »
able to connect a pc monitor up to the pc and see if it all works?
pvfoy
« Reply #4 on: September 15, 2004, 03:31:07 am »
the arcadevga card has only a 1 port  - for a jpac connection - so no i can't, but i have enabled agp on the bios.
did test the machine with a pc monitor when it had a pci vga card in and it worked fine.
i have read problems people have with arcadevga drivers but i'm not even getting a bios screen ???? so as to allow me to f8 and install the drivers - just a blue monitor?
RayB
  • There's my post
    • RayB.com
« Reply #5 on: September 15, 2004, 04:00:52 pm »
From what I recall from a bit of reading here and there, most newish arcade monitors default to a blue screen when they get no signal (can anyone confirm this?).
The fact that pressing a player button causing a ripple is a bit disconcerting. Do you perhaps have your connections mixed up? Did all buttons and joys work when you tested with a PC monitor?
Try testing with all controls disconnected. And double-check your JPAC jumper settings.
NO MORE!!
