Author Topic: Mamewah and EPSXE  (Read 1314 times)
APFelon
  • Last login:July 04, 2024, 08:51:53 pm
Mamewah and EPSXE
« on: September 13, 2004, 01:57:00 pm »
I have had some issues with the new version of Mamewah while running ESPXE on it. Here is what I have found.
After running the first game and exiting back to the main menu, a toolbar - sized line the same color as the desktop appears at the bottom of the screen.
This is the odd one-- Mamewah will constantly reload the last ROM played over and over and over with no way to get out of it other than ctrl-alt-delete. I exit the game, and Mamewah will simply reload the ROM in EPSXE. Strange stuff. It is not a hardware issue as far as I can tell.
I have not tried replicating any of this with any other emulator... just EPSXE. Not too sure if anyone else has played around with EPSXE and MAamewah 1.5 or not, but I thought maybe someone can confirm my findings.
APf
Minwah
    • MAMEWAH
Re:Mamewah and EPSXE
« Reply #1 on: September 13, 2004, 07:16:40 pm »
Not sure about this, but it sounds like MAMEWAH is losing focus after quitting ePSXe for some reason.  How are you launching it?  Last time I heard it had to be run from a batch file I think...
APFelon
« Reply #2 on: September 13, 2004, 08:08:32 pm »
Yeah, I am using a .bat file similar to the one found on the Mamewah setup site.  However, I didn't even think that it could be losing focus. I'll run some more tests and see what I can find.
APf
Minwah
    • MAMEWAH
« Reply #3 on: September 14, 2004, 04:30:26 am »
Just make sure you use the 'start /wait' part...
I've added code to try and stop MW losing focus...but I did notice that some apps just don't like to let go!  I'd set it up and have a go but I don't have any PSX games...
