Author Topic: need suggestions on mounting a comp monitor  (Read 1763 times)
Hoagie_one
  • Um....whats a cabinet
« on: September 13, 2004, 01:32:50 pm »
its gonna be mounted on a diagnal.  Any ideas on teh best way to do this?
crashwg
Re:need suggestions on mounting a comp monitor
« Reply #1 on: September 13, 2004, 04:29:47 pm »
when you say diagonal, do you mean:
1. Looking at the screen, you will be turning it 45
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Hoagie_one
« Reply #2 on: September 13, 2004, 04:36:44 pm »
#2
crashwg
« Reply #3 on: September 13, 2004, 04:47:38 pm »
Take the monitor out of it's case.  There are 4 mounting holes, 1 in each corner.  Use those to mount to some wood.  Only thing you have to worry about is the PCB (the board with all the electrical components on it).  You can't just let it hang, so you're going to have to find a way to support it.
Lemme say it again
goofy
  • Last login:January 03, 2005, 01:11:10 am
« Reply #4 on: September 13, 2004, 07:21:20 pm »
Don't you have to take the charge out of the monitor if you remove the casing? Or is that only for TVs?
Hoagie_one
« Reply #5 on: September 14, 2004, 03:19:30 pm »
i would think so...maybe he's trying to kill me
Crazy Cooter
  • Senator Cooter was heard today telling the entire congressional body to STFU...
  • Last login:August 19, 2025, 11:29:13 pm
« Reply #6 on: September 14, 2004, 03:26:52 pm »
Just watch where you put your fingers ;)
pointdablame
« Reply #7 on: September 14, 2004, 03:50:26 pm »
Before I say anything, know that I've never mounted a monitor on a diagonal.
That being said, I don't think you have to take it out of the casing unless you want to.  you could build bracing inside the cab with 2 (or more) beams going across the machine.  These beams could be at the angle you wanted, and you can rest the monitor on there.  With some careful measurements and deciding where the monitor should rest on the beam, it should work just fine.  You'd need to support it well of course, but I'd think it was more than possible.
first off your and idiot
« Reply #8 on: September 14, 2004, 04:07:52 pm »
Does taking it out of the case really save on space?  What would be the point otherwise?
Hoagie_one
« Reply #9 on: September 14, 2004, 04:30:32 pm »
if there is mounting brackets inside, then it would be a good idea, but im paranoid, so ill just work on a shelf to hold it in place.
« Reply #10 on: September 14, 2004, 04:38:26 pm »
I think I'm going with a shelf as well but if there is a real reason to open it up I will give it a shot...
